Author Topic: Reinstalling leaf springs  (Read 3762 times)
Offline anlauto
Re: Reinstalling leaf springs
« Reply #15 on: January 02, 2014 - 09:45:03 AM »
Yep...detailing job looks awesome !
 You'll never get it bolted in the car like that without leaving the U bolts loose. There's too many variables and angles to deal with. I hang the front of the spring in first, position the rear axle, then hook up the rear shackle.
In 1993 I did exactly what you're doing with a 7 1/4 out of my Duster Twister. I assembled it completely in my Parent's basement, then two of us carried up the stairs :screwy: :smilielol: The good ol' days...
« Last Edit: January 02, 2014 - 10:06:22 PM by anlauto »
Offline mrbill426
    • All Around Mopars
« Reply #16 on: January 02, 2014 - 09:48:47 PM »
Thanks for all the tips folks, I appreciate it, that's what I like about this site; a wealth of information at the asking with nothing left out  :)  I think I will take it back apart for the install because just leaving the U-bolts loose would probably result in my axle and spring paint jobs being tore up while jockeying things around.   I also appreciate the positive comments about the "detailing", I'm an amateur but I am trying.
I'm not totally pleased with the finish on the housing but it's on there now.  It is Por15 chassis coat black applied over their own self etching (greyish) primer.  I hope it holds because I had a heck of a time getting the top coat to "stick" to the primer even though the directions said no sanding was required, the brush kept pulling it back off :eek4: .  What bothers me is that when I rotated the housing on the jack stands some of the paint chipped off to the primer, I did not think it would do that :crying:.  Hopefully I can touch that part up.  Por-15 is pretty cool stuff but I have no plans to use it again; it's a pain in the neck.
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline mrbill426
    • All Around Mopars
« Reply #17 on: January 04, 2014 - 09:26:46 PM »
Does anyone know of a reasonable source for those one-time use 5/8" lock nuts that go on the front leaf spring bushing bolts?  I think they are called mardsen nuts, and they are (of course) discontinued at Mopar.
 :working:
MOPAR or NO car!
Offline anlauto
« Reply #18 on: January 04, 2014 - 10:21:32 PM »
Frank Baldenson, or R/T Specialities maybe.
Pretty certain AMK has them which mean Dave at Roseville can get them for you. You most likely have to buy the bolts too. :2cents:
