Wrong? No, not necessarily. Some guys like to install as a unit, some don't. I usually will install the springs into the front hanger, then install the housing on the springs, then lift the whole thing up and hook up the shackles.
If you install as an assembly like you have it, you will want to loosen up the u-bolt nuts so you can slightly move the springs side to side. This will be necessary to get them into the splayed mounting position. If you torque everything now as is, you're going to be fighting them to get them into the car.
