Author Topic: Thickness of spacer needed to properly tilt differential  (Read 1107 times)
Offline Racer57
« on: December 31, 2013 - 03:00:22 PM »
How thick of a spacer is needed at the rear mounting of the axel/differential to tilt it down 3 degrees ? Mine is going to most likely need tilted down due to using a Tremec 5 speed and would like to have an idea of what thickness of spacers to have on hand. If needed, I'll make my own using strap steel.
Offline Katfish
  • 70 Challenger
Offline Racer57
Re: Thickness of spacer needed to properly tilt differential
« Reply #2 on: December 31, 2013 - 05:03:43 PM »
Thanks for the reply !
I've seen the kits, but how thick are the spacers ?
Offline Katfish
  • 70 Challenger
« Reply #3 on: December 31, 2013 - 05:27:23 PM »
The "spacers" are triangles in shape.
You need to do some math to figure that out, a^2 + b^2 = c^2 and tan(theta) = O/A
Or someone might already have some they could measure.
« Last Edit: December 31, 2013 - 05:29:13 PM by Katfish »
« Reply #4 on: December 31, 2013 - 06:17:54 PM »
I made my own 3 degrees and they were about 3/8"-1/2" at the thickest point? If that helps?
Offline 72cudamaan
« Reply #5 on: December 31, 2013 - 07:29:32 PM »
They can be as thick as you want, as long as one end is thicker as shown in the previous post.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72cudamaan
« Reply #6 on: December 31, 2013 - 07:31:12 PM »
Okay, just measured a 3 degree shim. 5" long, 3/8th thick on one end, 1/8 thick on the other end.
Offline Racer57
« Reply #7 on: December 31, 2013 - 10:34:24 PM »
Thanks !!!   :clapping:
