Author Topic: How to not break seat stop bumper ?  (Read 1462 times)
Offline Racer57
« on: January 03, 2014 - 02:25:24 PM »
I got my replacement seat stop bumpers. How do you get them to fit over the studs without breaking them ? I was going to put them into hot water before trying to press them on, but thought I'd check here first.
Offline anlauto
Re: How to not break seat stop bumper ?
« Reply #1 on: January 03, 2014 - 02:29:45 PM »
I just did this a few weeks ago. I held the stud with ViceGrips, heated it "warm" with a torch and slip it right it. It did melt the plastic a bit, but it's not coming off again. :2cents:
Offline spamtank
« Reply #2 on: January 03, 2014 - 02:40:58 PM »
I used hot water.  No problems.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #3 on: February 02, 2014 - 12:17:38 AM »
I had bought new repop seat stop bumpers many months ago, and had not yet installed them. I did not realize that the stud's integral washer needed to go "inside" the nylon/plastic piece.  Well, I just did mine today.  Here are the steps I used to get the studs in:  I boiled the nylon/plastic pieces in a small pot of water for a few minutes, then took them out to the garage; opened the vice jaws slightly wider than the width of the threaded stud; placed the nylon piece on top of the vice jaws; put the stud through the hole, and using a large phillips screw driver (in the head of the stud) and a hammer, I pounder the stud into the nylon piece.  It went in without much effort, and spins freely inside.  No damage to the nylon/plastic piece, or the stud.  Thanks go to Racer57 for starting this topic, and to the members who replied with advice.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
« Reply #4 on: February 02, 2014 - 02:16:14 PM »
This is the type I have.
Is it the OEM design?
http://www.use.com/eae99b3e7807e2a0b59a
« Last Edit: February 02, 2014 - 03:06:17 PM by Topcat »
Offline filmsurgeon
« Reply #5 on: February 02, 2014 - 05:48:54 PM »
It doesn't look OEM to me, but then again, my buckets seat backs just had a bolt screwed in, instead of the correct type screw and nylon stop/bumper (another lazy and cheesy job done by the previous owner).  Here is a photo of the stop that nearly everyone sells as OEM replacement.
Offline anlauto
« Reply #6 on: February 02, 2014 - 06:23:48 PM »
Yes those are 100% OEM....
Offline filmsurgeon
« Reply #7 on: February 02, 2014 - 06:40:59 PM »
Interesting.  I assumed that the nylon bumper/stop with the phillips head large washer screw was how they were originally.  Too bad the style (in Topcat's photo) is not reproduced, but the ones I bought are definitely better than just a bolt.
« Reply #8 on: February 02, 2014 - 06:53:39 PM »
I cleaned mine up with Evaporust and RPM'd them.
Go to go.
Thanks for confirming that Alan.   :2thumbs:
