Author Topic: Hood install  (Read 1255 times)
Offline erat340
Hood install
« on: January 03, 2014 - 08:44:39 PM »
Hi-yo! Re foo-foo'd my engine bay in the chal. Anyone have any tips or slick tricks on the install, or moreso, the hinge to body, hinge to hood adjustments?
Offline 72cudamaan
Re: Hood install
« Reply #1 on: January 03, 2014 - 10:53:10 PM »
Yo, diddy boo foo. Get your sido the hoodo lined so the gaps are correct. If the hood is high in the back when closing, loosen
the side bolts and push the nose of the hood up while someone tightens the bolts. The FSM has a pretty good outline on hood
adjustment if needed. What is a foo-foo anyway?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline erat340
Re: Hood install
« Reply #2 on: January 04, 2014 - 02:43:14 AM »
Thanks 72! A foofoo is just a clean and paint while I pulled the auto and put a 4 speed in.
Offline 72cudamaan
Re: Hood install
« Reply #3 on: January 04, 2014 - 10:04:54 AM »
Gotcha.   :thumbsup:  Well as I hinted at, lining up a hood is far from rocket science. As long as you're not moving
fenders or the header panel. And it's much easier with 2 people.
Offline DocMel
Re: Hood install
« Reply #4 on: January 04, 2014 - 12:30:49 PM »
In the future, scribe around where the hinge meets the hood with a marker.  It will save you HUGE hassles in re-aligning.  For now, you might be able to see where the hinge met the hood from where they met.  Again, it will save HUGE hassles in time and adjusting if you place the hinge back where it was in the first place
Offline erat340
Re: Hood install
« Reply #5 on: January 04, 2014 - 08:02:48 PM »
Yeah, the scribe method , but ya know it was all cleaned and painted---can ya slide around/adj. w-o scratchin the paint? Dammit, I cant find my hood to hinge bolts!        AH_HA, I found them!
« Last Edit: January 04, 2014 - 08:37:38 PM by erat340 »
Offline sassygreen
Re: Hood install
« Reply #6 on: January 04, 2014 - 11:01:33 PM »
it is too late now but next time drill an 1/8 inch hole in the front and back of hinge mating area next to mounting bolts after hood alignment. During reassembly install ice picks into the holes then reinstall bolts. works for the doors and the trunk as well.
Offline erat340
Re: Hood install
« Reply #7 on: January 06, 2014 - 09:11:16 PM »
Oh yeah,SG, thanks for reminding me. I did drill alignment holes hinge to hood but not hinge to body. Where do you initially set hinge to body?
