Author Topic: Quarter glass seal removal and install?  (Read 2776 times)
Offline Katfish
  • 70 Challenger
« on: January 05, 2014 - 09:14:53 AM »
70 Challenger
How hard and what is the process to replace the quarter glass seals?
Do you have to remove the chrome channel, slide or glue in?
Offline anlauto
Re: Quarter glass seal removal and install?
« Reply #1 on: January 05, 2014 - 09:35:24 AM »
The verticle seal is just slid into a track in the stainless trim. I've seen glue used in 70 versions but not in the 71+ style.
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #2 on: January 05, 2014 - 10:42:02 AM »
e
So what's the process for removing the glass if it is in fact glued in. Any tricks or tips.
SOLD
Offline 72cudamaan
« Reply #3 on: January 05, 2014 - 11:06:11 AM »
e
Is the glass bad?
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: January 05, 2014 - 11:27:50 AM »
Is the glass bad?
It might just need to be polished. No deep scratches just dirty but I can't get it to clean up. My thought was to just replace it. Do they sell glass restoration kits? What would I use?
SOLD
« Reply #5 on: January 06, 2014 - 09:03:16 AM »
My original one just slid right out.  The new one was a PITA to install.  The seal was too big for the channel and I had to slowly work it down with a lot of force.  My fingers/wrists hurt for a week after.
Offline Katfish
  • 70 Challenger
« Reply #6 on: January 06, 2014 - 03:02:13 PM »
I'm thinking I should just transfer the chrome channel with weatherstripping to the new glass.
How would I go about removing and reinstalling the channel?
Any tips or how to's?
Thanks
« Reply #7 on: January 06, 2014 - 03:17:14 PM »
Are you replacing the seal or the glass...both?  The seal doesn't come with the stainless piece.  The seal just pulls out and the new one gets pushed in.  I think 70 has a different way of attaching the stainless piece to the aluminum frame.  My 73 just has one rivet holding it on at the bottom.
Offline Katfish
  • 70 Challenger
« Reply #8 on: January 06, 2014 - 04:32:05 PM »
I have my bad (scratched) glass with good channels and weather-stripping.
Bought some better glass with not-so-good channels and weather-stripping.
Want to transfer my HW over to the new glass.
« Reply #9 on: January 07, 2014 - 09:01:41 AM »
The channel should be held to the lower aluminum frame at the bottom somehow.  Mine used a rivet.  Have a look and see how it's attached.  The glass just pushes into the groove in the channel.  There is a gasket of sorts in the channel but the glass just pushes into it.  With the lower attachment point disconnected, the channel will come(should come) right off.
Offline 750-h2
« Reply #10 on: June 30, 2015 - 11:33:15 AM »
Realize this an old thread but I am doing this now and need to know if the rubber like channel used to secure the glass to the stainless trim is being reproduced? Mine broke apart when I removed the glass from the channels. Or is my only option black urethane? THANKS
