Author Topic: Front Spindle Casting Numbers  (Read 876 times)
Offline BADBURD
« on: January 06, 2014 - 02:45:39 PM »
I'm hoping someone can help me out. I have the front end apart on my 71 Cuda with drum brake spindles. I have lost track of witch one is left and right. They look very close to the same. Any help?
Offline Katfish
  • 70 Challenger
Re: Front Spindle Casting Numbers
« Reply #1 on: January 06, 2014 - 03:07:36 PM »
Easy way to tell is the caliper is fronted towards the front of the car.
Offline anlauto
« Reply #2 on: January 06, 2014 - 03:23:11 PM »
Not too many calipers on a drum brake car... :bigsmile:
I'm 100% certain they are the same left-to-right...
« Last Edit: January 06, 2014 - 03:29:14 PM by anlauto »
Offline BADBURD
« Reply #3 on: January 06, 2014 - 03:35:02 PM »
I thought they were the same also when I removed them. After some bead blasting I'm seeing 2 different casting numbers.
Offline anlauto
« Reply #4 on: January 06, 2014 - 03:38:44 PM »
Could be casting dates. :dunno: The 70-71 parts manual confirms the same part number for both sides. :2cents:
Offline BADBURD
« Reply #5 on: January 06, 2014 - 03:49:16 PM »
If the parts manual says they are the same that works for me. I know they look the same. Definitely not dates codes though. They are are long casting numbers.
Thank you very much for looking this up for me!
Offline Katfish
  • 70 Challenger
« Reply #6 on: January 06, 2014 - 04:29:47 PM »
oops sorry, didn't see the drum part
Offline 73EStroker
« Reply #7 on: January 10, 2014 - 12:27:47 PM »
A body drum spindles are same side to side if that helps.
Barry (Salmon Arm)
