Author Topic: Okay, one last electrical mystery wire question  (Read 1056 times)
Offline Chlngrcrzy
« on: January 07, 2014 - 10:50:30 PM »
These wires are behind driver side kick panel. They are not for the seat belt wires. i have those identified. Any ideas what they may go to.
Offline Jamiez
  • Retro
Re: Okay, one last electrical mystery wire question
« Reply #1 on: January 07, 2014 - 11:17:59 PM »
Rear speaker for a mono set up?  They run through there, down the rocker panel past the rear seat and then into the trunk.  The same path as the rear lighting harness.
Offline Chlngrcrzy
« Reply #2 on: January 07, 2014 - 11:35:42 PM »
Thats possible. I ran all new speaker wire, straight to the stereo. The old wire would still be inside the old harness, right?
Offline Jamiez
  • Retro
« Reply #3 on: January 07, 2014 - 11:56:21 PM »
Speakers were run as a separate harness from the tail lights.  They followed the same path but were physically separate.
The harness on the left is the radio harness for a mono set up with a fader, it ran under the dash and then behind the kick panel.   From there the harness on the right ran down the rocker channel and into the trunk.
Offline rattlesnake
  • Rattlesnake
« Reply #4 on: January 08, 2014 - 12:14:15 AM »
Dome light switch??
keep honking I'm reloading
Offline JayBee
« Reply #5 on: January 08, 2014 - 09:37:45 AM »
My vote is for door/dome light switch as well. In my 1970 Service Manual the connectors look the same BUT it says the wires should be yellow and yellow w/black tracer.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #6 on: January 08, 2014 - 09:58:43 AM »
Those are the door switch wires.  The DS has two connections...the PS just has one.  You don't have the door switch installed yet in your picture.
« Last Edit: January 08, 2014 - 10:02:17 AM by burdar »
Offline anlauto
« Reply #7 on: January 08, 2014 - 10:29:37 AM »
Door Jamb light switch... :dogpile:
Offline Chlngrcrzy
« Reply #8 on: January 08, 2014 - 10:43:28 AM »
:bricks1:  Dang i thought i had that hooked up!
