Author Topic: Wiper Linkage_Transmission Install?  (Read 744 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: January 08, 2014 - 01:47:27 AM »
What's the best way to install a 3-speed wiper linkage/transmission so as NOT to cause any "damage" to the new paint?  When I took it out, it was extremely tight fitting through the cowl screen holes.  I would think there's a way to get it back in without scratching the paint, but thought I'd check with you guys for advice.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline usraptr
Re: Wiper Linkage_Transmission Install?
« Reply #1 on: January 08, 2014 - 05:11:32 PM »
I haven't reinstalled mine yet,  but first bit of advise would be to mask off the openings with painter's tape.
(Edited 8-1-17)
Offline filmsurgeon
« Reply #2 on: March 17, 2014 - 02:58:36 PM »
Got the linkage in.  Regarding the bracket that attaches to the wiper motor (see photo).  Can someone confirm if I have the linkage bracket oriented correctly where it attaches to the back of the motor (motor is in the "park" position)?  I didn't note the position of the arm before I removed it, and don't know if it should by 180 degrees out.  Thanks.
