Author Topic: Is this water temp gauge reading properly or low ?  (Read 2319 times)
Offline Racer57
« on: January 10, 2014 - 11:19:42 AM »
70 Cuda
383cu
26" radiator
Is the DASH water temp gauge reading properly or low ?
« Last Edit: January 10, 2014 - 11:24:40 AM by Racer57 »
Re: Is this water temp gauge reading properly or low ?
« Reply #1 on: January 10, 2014 - 11:34:17 AM »
I think that's probably OK.  I have a 192 degree stat in my car and the gauge reads just less then half.(rebuilt and calibrated gauges)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: January 10, 2014 - 02:19:52 PM »
What temp thermostat you have in your Cuda?
Offline Racer57
« Reply #3 on: January 10, 2014 - 02:23:43 PM »
160
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: January 10, 2014 - 02:35:01 PM »
Looks like you are right on the money!
 :2thumbs:
« Reply #5 on: January 10, 2014 - 05:01:28 PM »
I can't comment on your after market gauge, but that's what I see on my Rally temp. gauge.   :thumbsup:
Offline Katfish
  • 70 Challenger
« Last Edit: January 10, 2014 - 05:25:39 PM by Katfish »
Offline Racer57
« Reply #7 on: January 10, 2014 - 05:33:29 PM »
Thanks for the replies. :clapping:
 I'll sleep a lot better tonight. Between bad gauges and getting a couple wires mixed up, I've had a hellva time putting the new cluster in. I finally got it done and everything works.
« Reply #8 on: January 10, 2014 - 06:38:44 PM »
 :2thumbs:
« Reply #9 on: January 10, 2014 - 07:50:44 PM »
160
Why? Engine was never designed to run a 160* t-stat.
Offline 72cudamaan
« Reply #10 on: January 10, 2014 - 08:24:44 PM »
  :iagree:  Seems way too cold.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: January 10, 2014 - 09:10:37 PM »
The original question was "is my water guage reading properly". The answer is yes.
Now onto the other topic of the best temperature for atomization of fuel the answer is as close to 180-190 as possible which lends itself to a 180 degree thermostat.
There you just got a 2fer!
 :bigsmile:
Offline Racer57
« Reply #12 on: January 10, 2014 - 09:39:42 PM »
Engine had been running too hot this past summer so I put it on hoping it would help.
« Reply #13 on: January 13, 2014 - 09:57:09 AM »
The only thing a thermostat does is regulate the lowest possible temp of the engine.  It has nothing to do with overheating as long as it's not stuck closed.
Offline 74 challenge
« Reply #14 on: January 14, 2014 - 08:43:34 AM »
My non-rally guage reads exactly the same but I have a 180 t-stat and an overkill 3 core rad for my 318.
1-8-4-3-6-5-7-2
