Author Topic: COIL WIRES REVERSED?  (Read 1012 times)
Offline arcticmopar
  • Yukon Canada
« on: January 11, 2014 - 05:03:53 PM »
If I mixed up the two wires to the coil on my  70 chally w/ electronic ign. would it still fire up?  :clueless: About five years ago when I last had the engine out, I didnt mark the darn wires, :dupe: It fired right up so I figured I got it right but since I got the engine out again I would do it right for a change! :thinkerg:
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Re: COIL WIRES REVERSED?
« Reply #1 on: January 11, 2014 - 05:20:43 PM »
it will usually work but the spark will not be so good .
Offline jordan
« Reply #2 on: January 11, 2014 - 06:51:02 PM »
Which wire goes to the +??
« Reply #3 on: January 12, 2014 - 01:29:26 AM »
brown 12v + while cranking 7v running
« Reply #4 on: January 12, 2014 - 01:21:55 PM »
I seem to remember a black wire with a yellow trace being on my negative.
« Reply #5 on: January 12, 2014 - 05:57:36 PM »
Correct , the Electronic ign uses a black / yellow trace wire on the - coil terminal
« Reply #6 on: January 13, 2014 - 05:11:59 PM »
Did you doubt me Neil??   :lol:
I should have said this wire was on the electronic ignition conversion kit. It wasn't on the stock 1970 wiring harness.
« Reply #7 on: January 13, 2014 - 05:36:09 PM »
I trust you Mike , You know your stuff , Just clarifying that it is with the Mopar electronic ign only
Offline arcticmopar
  • Yukon Canada
« Reply #8 on: January 15, 2014 - 07:21:52 PM »
Thanks for the clarification guy's. I know my car was converted to electronic but I didnt want to just the colour of the wire.
