Author Topic: E Body seat tracks  (Read 2844 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
E Body seat tracks
« on: January 12, 2014 - 04:08:10 PM »
Finally had a chance to blast my seat tracks from my 70 Challenger. looking now for the right primer and paint color. What is correct for color? What a good primer?
Thanks
SOLD
Offline usraptr
Re: E Body seat tracks
« Reply #1 on: January 12, 2014 - 04:59:25 PM »
 :popcorn:
(Edited 8-1-17)
« Reply #2 on: January 15, 2014 - 09:55:08 AM »
Recently stripped off the old seats off of the bucket frames.
The back of the head rest was gloss black.
I don't know if the tracks were added after the seat or together when they painted it.
I believe the tracks were added after being covered.
I'll be going semi gloss black on the tracks this week-end.
Offline Racer57
« Reply #3 on: January 15, 2014 - 12:17:37 PM »
I had mine powder coated which gloss black. It was the best way to get rid of the rust.
« Last Edit: January 15, 2014 - 12:19:11 PM by Racer57 »
« Reply #4 on: January 15, 2014 - 03:32:47 PM »
Had mine Powder Coated but had it done while they were together. BIG mistake. That was before I found out how to take them apart. Now that they are disassembled just going to paint.
SOLD
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #5 on: January 16, 2014 - 01:33:12 PM »
When I did my seat tracks, I disassembled them (which was a PITA to figure out how to do), then soaked in heavy duty degreaser for a couple of days (which also removed the paint).  Then spray-painted the 8 halves semi-gloss black.  I haven't yet reassembled them, but am hoping that the paint holds up after installation.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline dakota
« Reply #6 on: March 12, 2015 - 09:29:45 PM »
How did you take apart the seat tracks?   The only approach I can see at the moment is to grind and knock out one of the heavy rivets and hope that the roller and bearing slides will come out.
Offline jhaag
« Reply #7 on: March 12, 2015 - 10:25:09 PM »
Read this thread. Tacks are not riveted together. Just bend the tab down on the end and they will slide apart.
http://www.cuda-challenger.com/cc/index.php?topic=90931.msg902549#msg902549
love 70 Challengers
Offline dakota
« Reply #8 on: March 13, 2015 - 06:46:25 AM »
Thanks!  I kept looking for something to bend on the bearing holder, not the end of the track.   Once I scraped some of the gunk off AND looked in the right place, the rest was pretty easy.   Much obliged.
« Last Edit: March 15, 2015 - 07:12:47 PM by dakota »
