"H" or "X" Exhaust ?
Author Topic: "H" or "X" Exhaust ?  (Read 9047 times)
Offline Skunkworks Challenger
  • Mopars forever!
Re: "H" or "X" Exhaust ?
« Reply #15 on: January 14, 2014 - 11:14:07 AM »
Quote
X-Pipe - Stop by the shop and check out our X-Pipe systems. We are adding new systems all the time! Or you can give us a call to check on the system you are looking for.
X-Pipe - How it works. Beware of mass produced, pre-stamped X-pipes that create too much turbulence and do not perform the way they should. A properly built X-pipe does not allow the exhaust to cross over from one side to the other, much like a traffic intersection. This creates too much turbulence and leads to a "traffic jam." They do seem to work at lower rpm’s when exhaust pressures and volumes are lower, but at higher rpm’s these open type X's that blow directly from one side to another create restriction and turbulence witch will slow down each pulse and lead to a loss of power and performance. Not only that, but mass produced, pre-stamped X-pipes can create unwanted harmonics from the turbulence caused by the exhaust fighting its way through the X from one side to another.
To understand how a properly built X-pipe functions we must first understand the difference between back pressure and restriction. For each combustion coming out of a chamber there is a pocket of high
pressure which is restriction or the force of resistance that the exhaust system puts on each pulse and behind each pulse of high pressure is a vacuum pocket of low pressure which has been known as back pressure. Scavenging is the process through which the vacuum pocket behind one pulse actually pulls the following high-pressure pulse along. An exhaust system with too much restriction or to little restriction will loose its ability to scavenge and therefore cause loss of power and performance.
In a properly built X-pipe as the high pressure pulse sweeps buy the opening in the connection of the pipes from each bank of the engine, its restriction is relieved from the low pressure pocket coming from the opposite bank. This increases its velocity and increases the back pressure just enough to increase the scavenging of exhaust gasses both at low and high rpm's resulting in greater power and performance.
The above is from the Olympia, WA  Quality Muffler and Brake Shop that built and installed my X-pipe.  These guys pioneered the X-pipe but never patented it.  Now everybody makes one.  These guys have jigs for popular muscle cars and can make one in a few minutes.  They maintain and stress "not all X-pipes are the same" and that many offer no advantage over H-pipes.
The Brewmaster
Offline cudabob496
« Reply #16 on: January 14, 2014 - 05:42:57 PM »
I think TTI recomends that the X pipe should have a little tack weld to hold it in place. That would make it a little more difficult to remove. However even the H pipe takes a little effort to seperate after the clamps have been tightened a couple of times.
Jack
Yes, they do, but I've found its not necessary, and my entire X-pipe center section is staying firmly in place with four pipe clamps.
The X-pipe section is pretty light.
« Last Edit: January 14, 2014 - 06:21:46 PM by cudabob496 »
2011 Kawasaki Z1000
Offline johannes
« Reply #17 on: January 15, 2014 - 05:52:16 PM »
You will have a hard time installing an OverDrive if you choose the "X".
Aside;
Another issue is what type of flexible joint you plan to install....
There will be quite some engine "twist" with a high torque engine,..and the 3" pipes does not bend much....
Without flex allowance an unknown amount of force will be transmitted to header-bolts and exhaust suspension....
Offline cudabob496
« Reply #18 on: January 15, 2014 - 06:22:24 PM »
Aside;
A high torque engine should have a torque strap, such as the one Schumacher sells. Also, even if engine twists, the
exhaust piping is just hanging from the frame/body.  Because its hanging, it will freely move with the engine.
2011 Kawasaki Z1000
Offline anlauto
« Reply #19 on: January 15, 2014 - 06:26:02 PM »
The entire exhaust is rubber mounted to the body in most cars...It moves with the engine....now whether or not it hits the chassis is a different story.
The car I'm working on will have a TKO 600 for a transmission. I don't think either pipe will be a problem.
« Last Edit: January 15, 2014 - 09:46:08 PM by anlauto »
« Reply #20 on: January 15, 2014 - 09:29:14 PM »
Aside;
I have the magnaflo kit on my car . It has an X , and I have an OD automatic. Lots of room.
Offline PlumCraZRT
« Reply #21 on: January 16, 2014 - 02:12:05 AM »
The rubber mounts should be considered rigid, but used for noise isolation.  You can still transmit tons of load using rubber mounts (look at your suspension).
mmmmm.... Mopar.... *drool*
Offline 4Cruizn
  • HEMI FISH
« Reply #22 on: January 16, 2014 - 09:29:59 AM »
I actually have both setups . . . Not sure I like one over the other?    :dunno:
Offline ChallengerHK
« Reply #23 on: January 16, 2014 - 09:36:04 AM »
Are both of your drivetrains similar, Dave?
- Han Solo, Star Wars
Offline 4Cruizn
  • HEMI FISH
« Reply #24 on: January 16, 2014 - 11:00:51 AM »
No actually I have an H pipe in the hardtop that features 500 ci stroker with hemi 4 speed and then X pipe in the convertible with 440 auto.  I will say that I am able to remove the trans in the hardtop without doing anything with the exhaust but if I needed to in the convert, I would have serious issue and would need to remove the exhaust to get that trans out.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #25 on: January 17, 2014 - 05:40:31 AM »
After reading this thread I have a question.  What is going on, whether its good or bad, with a dual exhaust system which has neither H or X crossover?
« Last Edit: January 17, 2014 - 05:50:28 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #26 on: January 17, 2014 - 05:18:14 PM »
There is a difference in sound from the "H" and "X" pipes. I like the "H" for that, but the "X" has been proven to be more efficient. So we are really splitting hairs here in my opinion. You could get better sound, and a few more HP with the "H" or "X" system, but if you like yours, no way would I change it out.  It's not worth it.
Offline todd383
  • I'm a llama!
« Reply #27 on: January 17, 2014 - 06:31:31 PM »
well..... when i had my 08 shelby gt500, we did exhaust test between x and h pipe.  h-pipe was more throatier and low, where the x pipe was more high pitched, the difference in hp was not much at all, like 3 hp more with the x-pipe at 5000 rpms!
« Reply #28 on: January 17, 2014 - 06:38:58 PM »
Exhaust note and a small amount of horsepower, probably undetectable by the seat of the pants dyno.  :2cents:
