Author Topic: My Bare Bones 71 Cuda Convert Build  (Read 60615 times)
Offline AARuFAST
  • AARuFAST
Re: My Bare Bones 71 Cuda Convert Build
« Reply #165 on: August 30, 2015 - 09:26:23 PM »
Great job.   :cheers:
Is there something to put over the staple holes to keep it from deteriorating.
  Wonder how much harder to install if it was a vinyl top,,,,,
My Gran Cpe should have white vinyl top--has black.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline CudamanTom
« Reply #166 on: August 30, 2015 - 09:36:11 PM »
I have always wondered how they did this as the cars came down the assembly line.  :dunno:  Nice work Tom, and as my upholstery guy says, " let er sit in the sun, she'll be perfect "   :roflsmiley:  And it's true.   :2thumbs:
Thanks Mark. I still wonder how they did it at the assembly line. Had to been much easier and faster. You have me wondering on that.  :clueless:
And yes, the sun helped to "almost" perfect.  :bigsmile:
I'm still looking into what can be done with some of the other imperfections (bumps/bulges from the frame). Maybe a thin layer of foam here and there possibly. I see the same thing on other e-body convertible top installed. So it tells me it's normal but... I want just a little better if I can.  :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline CudamanTom
« Reply #167 on: August 30, 2015 - 09:39:31 PM »
Great job.   :cheers:
Thanks for your comment.  :wave:
I don't know if there is something to help with the staple holes or if maybe they will cure a little better over time in the sun, or get worse.  :dunno:
As for a vinyl top, I would think it's MUCH easier than a convertible top.
Offline ShelbyDogg
« Reply #168 on: August 30, 2015 - 10:12:54 PM »
Nice job Tom, glad I could help out. Now you know why someone would charge us $1000 to $1200 to install one and they would not try to make it as perfect looking as we the owners would.
One thing I've heard since owning a convertible. Black tops are a lot hotter than white tops. When cruising in HOT weather, night cruising with the top down is perfect under the stars.  It's hard to look cool Cruising in a convertible while sweat is pouring down  your forehead, so look for some add on a/c.
Offline Finoke
« Reply #169 on: August 31, 2015 - 06:24:36 AM »
All I can say is Your Cuda is looking awesome   :wow:
You have my respect doing your own convertible top. I'm just so intimidated by that job. Especially if you don't have the old top to remove first. As far as some things that didn't go quite right. Well thats any job. Most of what I do has to be touched up when done. Thats part of the challenge and fun  :clapping:
Thanks for posting all the pictures and comments. Im saving this thread and maybe I will be brave enough to do the top on mine someday.  :bigsmile:
Offline CudamanTom
« Reply #170 on: August 31, 2015 - 07:05:46 AM »
Thanks Rob.  :wave: I can definetly see why they charge what they do to install them. I still would have chosen to try it myself, if anything to learn.
And I had a white top cuda convertible at one time and I'm sure there is a difference in temps on a hot day versus the black top. I do plan to install A/C one day. I've been keeping my eye on Jim's (ToxicWolf) build thread where Mark (Roadman5312) installed the Vintage Air system in Jim's chally. I'll be picking Mark's brain about that when the time comes.
Offline CudamanTom
« Reply #171 on: August 31, 2015 - 07:07:27 AM »
Thank you Tom  :wave: ,
It's so cool to be a part of this forum, to share but also learn from other's as i have here.  :ylsuper:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #172 on: August 31, 2015 - 08:07:26 AM »
Looking good Tom!!  You have much more patience (and skill hahah) than I will ever have
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline dutch
« Reply #173 on: August 31, 2015 - 08:28:47 AM »
that`s looking really good   :bigshades:   I`ve seen cars roll out of profi shops that didn`t look anywhere near as good.  Too bad about the stapleholes, but hey... the whole idea of a vert is to have the top down ,right?    :bigsmile:
now hurry up and get some rubber smoking...  :burnout:
*** Bart ***
Offline YellowThumper
  • I left the snow for this?
« Reply #174 on: August 31, 2015 - 11:09:11 AM »
Agreed on "nice job" there.
I also tend to jump in with both feet. At end of day (even with a few small hiccups) it feels better than just writing the check.
« Reply #175 on: October 25, 2015 - 11:24:31 PM »
Congratulations Tom.
It has to be the biggest hurdle on a vert.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #176 on: May 08, 2019 - 11:19:12 AM »
THEN, started the swap from drums to disc in the front.
Let me tell you. The pickle fork days are gone!!! Now more fork for the tie-rod ends or ball joints or what ever needs a pickle fork.
This puller is the cats meow!!!  :ylsuper:
And got it today at Harbor Freight for $21.00  :2thumbs:
[/b]
All you need to do a whole spindle swap from drum to disc is four tools.
[/quote]
Tom, does that HF Ball Joint tool damage the castle nuts?  or do you flip the nuts, or use it without nuts on the ball joint bolt?
Car looks great!
Thanks,
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline 70chall440
« Reply #177 on: May 08, 2019 - 02:00:33 PM »
Truth be known, pickle forks were never supposed to be used on Mopars. Yes, we (mostly) have all used them but Mopar recommended impacting the sides of where the tapered pivot is inserted. If you look at the spindles you will see a square flat spot, this is for hitting with a hammer which releases the tension on the pivot (ball joint). I've heard of some guys who use an air chisel with a blunt attachment to act as a hammer to hit the joints as well but I have never had much luck with that technique.
Current Mopar
Past Mopars
