Author Topic: Park Brake Warning Light Bulb Socket  (Read 893 times)
Offline Tonker1
« on: January 14, 2014 - 08:42:15 PM »
I have a '73 Rallye Gauge Cluster and I'm trying to work out what sort of bulb socket I require for the park brake warning light. The car did not have one when I bought it.
From the original wiring diagram I believe it is a 2 wire socket.
Any help would be appreciated.
Offline Tonker1
Re: Park Brake Warning Light Bulb Socket
« Reply #1 on: January 21, 2014 - 07:04:21 AM »
Question bump? A photo of that region on the back of the gauges would be enough
Offline anlauto
« Reply #2 on: January 21, 2014 - 07:26:58 AM »
I don't have a picture handy, but you're correct. It has two wires running into it. One is a solid black wire, the other is dark blue with a tracer. :2cents:
Offline Tonker1
« Reply #3 on: January 21, 2014 - 07:37:27 PM »
Cheers, just wanted to make sure before I purchased parts or wired it wrong. I've been having a hard time tracking down the original style 57 bulb sockets.
Bulb type 53 sockets are readily available with the correct diameter clips, so I'll use one of those.
Offline imopar
« Reply #4 on: January 21, 2014 - 09:59:25 PM »
Mine isn't a rallye - I'm not sure if they are the same as far as this kind of stuff, but here are some pics of mine if it helps - standard cluster from my 73...
Offline anlauto
« Reply #5 on: January 21, 2014 - 10:05:27 PM »
Man when I think of the amount of wiring harnesses I've thrown away or sold on my $2 tarp.....It's times like this that a used one would come in handy....if only you lived closer... ::)
Offline Tonker1
« Reply #6 on: January 22, 2014 - 05:00:07 AM »
For the lighting they are the same, cheers for the photo.
Thanks for the consideration, I have a whole range of parts brewing on summit racing order, adding a light socket to the list shouldn't blow the budget... yet!!!
I kept the original non-functioning wiring harness in the car for as long as possible while installing the painless system. Until one day I chucked a mantrum and started slicing until all of the old harness was sitting in a bucket. I occasionally look through my bucket of wiring and pull out useful pieces.
