Author Topic: can it handle it  (Read 2148 times)
Offline Semi Hemi
  • I'm a llama!
can it handle it
« on: July 18, 2002 - 11:29:35 PM »
I want to build an engine like the one they did in mopar muscle the 360 that put out 608 some odd horse power but i don't think the stroker kit i want to buy can handle it heres the website. I'm not sure which kit i want but it needs to be able to handle 650 horse at least.
http://www.flatlanderracing.com/stroker340416.html
and if you know of any other stroker kit companies i'd like to know which other ones are out there.
Thanks
Re:can it handle it
« Reply #1 on: July 19, 2002 - 03:32:13 AM »
 Not enough info , How long are the Pro-line rods
I would just build my own Get the crank from Mopar or Eagle,  Manley or Lunati rods with a longer than stock lenght & have a custom piston made to fit the combo with a raised pin height. Y ;)ou can lose a lot of power if the rod ratio is not maintained
Offline Semi Hemi
  • I'm a llama!
Re:can it handle it
« Reply #2 on: July 19, 2002 - 09:34:09 PM »
do you think a cast crank is good enough or should i get a billet or forged or something else.
my bad
Re:can it handle it
« Reply #3 on: July 20, 2002 - 02:54:55 AM »
 If you want 600hp I wpould use a steel crank [forged or billet ] ;)
