Author Topic: Hydraulic clutch options?  (Read 2100 times)
Offline 4spdChally
« on: April 10, 2005 - 09:18:59 AM »
Has anyone experimented or converted to a hydraulic clutch over the original linkage? Is there a junkyard setup that would work well? I ask because I am converting an automatic over and I found a wrecked Mustang GT with a 5 speed and thought maybe the setup could be retrofitted in a Challenger. I wonder if the clutch/brake pedal set up would also work instead of having to pay for the high priced anbd hard to find original pieces. BTW I am trying to build a "wife" friendly clutch set up.
Thanks
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Hydraulic clutch options?
« Reply #1 on: April 10, 2005 - 01:50:46 PM »
Yep I been running hydraulic for years and years . Wife friendly ...then hydraulic is the way to go 4 sure especially if you have a heavy clutch in it. As for the mustang system ..I never seen one to tell . I switched from a auto to stick and without the factory pedl setup and  z bar using mechanical linkage is a nitemare. Originally I ws given a master & slave off a sprint car that had International Harvester on it. This year I replaced it witj a new master and slave for the same thing BUT there are better combinations so dont copy mine.Just keep in mind that you want at least a 1" bore on the master (preferably more) and as long a stroke as possible and the slave should be at least 7/8 to 1" bore and at least a 2" stroke. This willl give you more than enuff volume and stroke to be able to adjust and not have to pump to get full release .
look for truck masters and get the associated slave.
Offline Robb
« Reply #2 on: April 10, 2005 - 08:17:43 PM »
Keislers has them for your e-body
keislerauto.com
http://keislerauto.com/mopar/transmissions/clutch-link-kit.html
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline OUTLAW
« Reply #3 on: April 10, 2005 - 08:29:32 PM »
I liked that until I hit "buy "  499.00....ouch
but nice kit to copy anyway
« Reply #4 on: April 11, 2005 - 12:06:05 AM »
I have used both a Tilton & McLeod , I like the McLeod better , it works great though
Offline 1973challenger360
« Reply #5 on: April 11, 2005 - 04:17:56 PM »
wife friendly,     so you probably have power steering and brakes to                    :cry:  power robbers/weight adders  :cry:
Manual steering/brakes/clutch   for the work out in the car  :thumbs:
Offline 4spdChally
« Reply #6 on: April 11, 2005 - 04:34:34 PM »
Yep, trying to make a nice reliable driver out of the Challenger. It makes it easier to buy stuff if she thinks I am doing it for her too. I am also looking at a Ford EFI conversion like 1974Cuda360 is running.
I have a 5.9 Magnum and an A518 automatic that I am having checked out also as that may go in. Right now the project it is in the "design" stage.
If I want to break as sweat I take out my dad's '68 Super Bee 383. No power steering or brakes and an 11" clutch. :burnout:
« Reply #7 on: April 11, 2005 - 05:00:39 PM »
I wouldnt put it in a e or b body but an a body swap with a 3.9 liter and a 5 speed would be cool, read crashed Dakota
