Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
What size is the aluminum bell housing
« previous
next »
Print
Pages: [
1
Author
Topic: What size is the aluminum bell housing (Read 596 times)
Chlngrcrzy
Sr. Member
on:
January 19, 2014 - 05:54:20 PM »
Are all big block aluminum bell housings 10.5" or can some of them be 11"?
I am trying to order the correct Z-bar and service kits for it and the clutch. I am pretty sure mine is an 10.5", but i want to be certain. Mine is aluminum.
Logged
73EStroker
Sr. Member
Re: What size is the aluminum bell housing
Reply #1 on:
January 19, 2014 - 06:30:30 PM »
I believe your flywheel determines bh size - ie 130 tooth you need a 10-1/2" bh and 143 tooth you need a 11" bh. If you use 11" bell on small flywheel the starter won't engage properly. Most of the new aftermarket units are aluminum. Originals came in both and to determine what you have you need something like Govier books or simply post the casting number and I will check my books for you.
Last Edit: January 19, 2014 - 06:32:54 PM by 73EStroker
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
January 19, 2014 - 06:51:41 PM »
In My experience alum are 130 tooth cast iron are 143 tooth
Logged
Chlngrcrzy
Sr. Member
Reply #3 on:
January 19, 2014 - 07:17:19 PM »
Quote from: Chryco Psycho on January 19, 2014 - 06:51:41 PM
Sweet. Thanks. Mine is a 130 tooth. I thought it was a 10.5"
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
January 19, 2014 - 09:26:43 PM »
The 10.5 is the same bolt pattern as the 10.95 clutch so I always use the larger clutch , it has more surface area & from a leverage standpoint .5" is a lot more
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
