Author Topic: Cragar ss. Back spacing  (Read 572 times)
Offline stang13
« on: January 19, 2014 - 08:51:17 PM »
I'm checking the back spacing on my 70 challenger I think the cragars on the front may be the wrong backspacing because it's hitting the fender on tight turns another problem is the rim has a 215 x 70 x 15 tire on it. What is the correct backspacing to run on the front ?
Offline stang13
Cragar ss back spacing question
« Reply #1 on: January 19, 2014 - 09:07:19 PM »
Thanks
Re: Cragar ss back spacing question
« Reply #2 on: January 19, 2014 - 09:15:51 PM »
4.5" works with an 8" wheel.  Mine is 5" with a 9" wheel - 255/40/17 rubber
Re: Cragar ss. Back spacing
« Reply #3 on: January 19, 2014 - 09:27:27 PM »
4" with a 7" wheel, 4.5" with an 8" wheel,  and 5" with a 9.
YMMV due to manufacturing variances. :grinyes:
Offline anlauto
« Reply #4 on: January 19, 2014 - 09:28:11 PM »
 :iagree: Stock 15 X 7's had a 4.5 back spacing....I think if you have 7" or wider you should have at least that. :2cents:
Offline joelson6
« Reply #5 on: January 20, 2014 - 06:47:57 AM »
i've got 14" with 3.375 back space. 225/70/14 BFG tires and i get some rub too. i just figured that was par for the course
