Author Topic: Cuda rear valance  (Read 1241 times)
Offline Travis72
Cuda rear valance
« on: January 19, 2014 - 10:49:05 PM »
The rear valance on my 72 Cuda vibrates and rattles like crazy.  Is something supposed to connect to this hole on the bottom of the rear valance?
Thanks,
Travis
72 Cuda
Offline 67vertman
  • Member since 9-23-2005
Re: Cuda rear valance
« Reply #1 on: January 19, 2014 - 11:09:34 PM »
Yes, there is a capyure nut and bolt that goes there.
Offline anlauto
« Reply #2 on: January 20, 2014 - 07:01:03 AM »
No, not in 1971+ Cudas. :2cents: The extra supports that ran down behind the gas tank were a 70 only thing. :2thumbs:
Offline Travis72
« Reply #3 on: January 20, 2014 - 08:39:19 AM »
Hmmm is there a way to retrofit it?  My only other thought is to try putting dynamat type material on the inside of the valance.
Travis
72 Cuda
Offline 72cudamaan
« Reply #4 on: January 20, 2014 - 08:57:07 AM »
Travis
72 Cuda
Not sure, but I think the 70 brackets will attach. Just not original.  :2cents:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline anlauto
« Reply #5 on: January 20, 2014 - 09:12:26 AM »
See the bracket in the top righthand corner of your picture held on by two 7/16 head bolts.....
You would have to replace those brackets with the 1970 style available in reproduction. http://www.ebay.com/itm/VALANCE-PANEL-CROSSMEMBER-BRACKET-CUDA-E-BODY-70-AMD-BRACKET-REAR-BACK-/130939304228?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1970%7CModel%3ACuda&hash=item1e7c973924&vxp=mtr#ht_568wt_780
Offline Haddixj
« Reply #6 on: January 20, 2014 - 09:24:54 AM »
Is it normal for the rear valance to rattle? There must be something that can or should be done
Offline anlauto
« Reply #7 on: January 20, 2014 - 09:31:46 AM »
Typically with all the correct hardware in place, they shouldn't rattle or need the extra support.
I see the original poster has an aftermarket gas tank so there's really no telling what the valence could be rattling against. :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: January 20, 2014 - 02:05:37 PM »
Here's a pic and mine isn't even hooked up, one more touch up piece the body shop gets to do.
Offline Edison1970
« Reply #9 on: January 20, 2014 - 05:08:18 PM »
It shouldn't rattle.  Make sure the bolts to the speed nuts on the bottom of the quarters are tight.  Also the ones along the top.  It might be rattling against the quarters since they don't always fit that well there.  Sometimes when you tighten the bolts, it pulls the steel tight only where the bolt is and the length of steel between the bolts fit is loose.
Offline 67vertman
« Reply #10 on: January 20, 2014 - 11:31:33 PM »
Good to know....Mines a 70 so it has a bolt.
