Author Topic: Floor Pan Seat Mounting Reinforcement Brackets?  (Read 2796 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: January 20, 2014 - 02:35:27 PM »
Did all E-bodies have these inboard brackets/braces on the underside of the floor pans (see red circled areas in photos)?  My '70 Challenger Convertible does not have them, but the outboard brackets/braces ARE there, and I believe the floor pans are original, but not 100% certain.  If all E-bodies had them, does anyone know if these are being reproduced?  Were the welded in?  Thanks
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline crocha617
Re: Floor Pan Seat Mounting Reinforcement Brackets?
« Reply #1 on: January 20, 2014 - 02:56:46 PM »
AMD includes them when you buy a full front floor pan. Not sure if they sell them separately or not. I can't imagine they don't.
Offline anlauto
« Reply #2 on: January 20, 2014 - 03:25:48 PM »
They are not found on bench seat cars :2cents:
Don't know that they are sold separately
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: January 20, 2014 - 03:55:06 PM »
We made some for my convertible when we did the cars interior.  Spot welded them in  . . . .  :dogpile:
Offline filmsurgeon
« Reply #4 on: January 21, 2014 - 12:21:52 PM »
Just spoke with AMD.  They do not have a part # for these pieces, as they receive the floor pans with braces attached.  However, the guy I spoke to took my name and number and said he'd look into it and get back to me.  Keeping my fingers crossed, but pretty sure they won't be able to help me out.
Offline filmsurgeon
« Reply #5 on: January 21, 2014 - 12:35:05 PM »
Can you tell me how you made them, and what the dimension are?  Were you able to recess the center of the plates for the seat-track stud hole? Thanks.
Offline hemiken
« Reply #6 on: January 21, 2014 - 04:32:40 PM »
Does your convertible have a fender tag  :popcorn: interested to see if it is coded for a bench seat please, this may be a way to see if your floor has been changed or not. :2thumbs:
Offline filmsurgeon
« Reply #7 on: January 22, 2014 - 02:55:34 AM »
Here you go.  Bucket Seats (no bench).  FYI - These seat track reinforcement plates are not the only things I found missing from the underside of my floor pan.  I recently bought a new E-Brake cable set.  When I went to install it, I found that the front cable guide bracket (just before the equalizer) was not there.  Luckily, I was able to get one from AMD.  The prior owner did A LOT of funky stuff to this car when he did his "Resto-Mod".  I am CONSTANTLY finding things I need to correct and fix.  Once I think I've turned the corner, I find something else that send me right back.
Offline hemiken
« Reply #8 on: January 22, 2014 - 04:29:18 PM »
Thanks for sharing, it would be frustrating as you say to keep finding funky things the owner before you has left off the car. :wave:
Offline AussieMark
« Reply #9 on: February 04, 2014 - 07:15:22 AM »
my 70 Barracuda has them and it has a split bench seat? I am replacing the floor pans so they are yours if you want them they will need the surface rust cleaned off'.
Offline ToxicWolf
« Reply #10 on: February 04, 2014 - 02:28:55 PM »
I'm not sure why they included those mounting points but I used them when I added 6 way set tracks. The 6 way traks have those braces you can buy separately.
