Holley connection for accelerator cable
Author Topic: Holley connection for accelerator cable  (Read 2265 times)
Offline Chlngrcrzy
« on: January 20, 2014 - 08:11:56 PM »
Have a new Holley carb and i am trying to come up with the proper connection for the accelerator cable. I need to order a taller bracket to match the Edelbrock Rpm Dual plane manifold i have. I found one through Mancini and i think my cable will be long enough, but i am not sure where it connects. I have a pointer showing where i think it connects, but it doesn't match the cable end. Am i missing something else?
Re: Holley connection for accelerator cable
« Reply #1 on: January 20, 2014 - 08:17:43 PM »
Mopar linkage adapter 20-7 if I recall bolt onto the arm & positions the pin correctly http://www.summitracing.com/int/parts/hly-20-7/overview/
« Last Edit: January 20, 2014 - 08:20:08 PM by Chryco Psycho »
Offline Chlngrcrzy
« Reply #2 on: January 20, 2014 - 08:51:36 PM »
OH Sweet. Thanks a bunch. That definitely simplifies things.    :2thumbs:
« Reply #3 on: January 20, 2014 - 09:45:00 PM »
Yes it does , Don't have to buy from Summit just the first place I looked for it , Jegs or most local speed shops will have it , I would send you one if I had access to them but they are in Canada 1000s of miles from me
Offline Chlngrcrzy
« Reply #4 on: January 20, 2014 - 10:03:27 PM »
i really appreciate your kindness. I have found a couple on -line and am in the process of getting one now. Thanks
Offline 73EStroker
« Reply #5 on: January 31, 2014 - 08:13:15 PM »
……. and I used a small block throttle cable bracket on my B block application to raise the cable higher so that it lined up more horizontal with the throttle pivot hole on the carb. Simply cut from below enough to allow the bolt holes on the bracket to be spread apart then once it fit on the manifold bolts I took it off welded/ground smooth and painted. Looks like it was made to fit.
Barry (Salmon Arm)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: February 01, 2014 - 02:52:06 PM »
Just got one of these for a tall manifold and it has everything - fast shipping too!
http://www.ebay.com/itm/321303447716?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Offline cudabob496
« Reply #7 on: February 01, 2014 - 03:08:27 PM »
Ehrenberg, the seller, is the MoparAction mag tech guru.
2011 Kawasaki Z1000
Offline Chlngrcrzy
« Reply #8 on: February 01, 2014 - 08:26:58 PM »
Thanks for all the help guys. I have it all hooked now. Looks good and works great. Only concern i have is my throttle cable seems a bit long and has a odd twist to it, but it seems to work just fine. And the accelerator peddle also seems really hard to push down. I have the identical tall bracket and as well as a tall spring return bracket. Are you suppose to use both the springs or just one of them?
Offline cudabob496
« Reply #9 on: February 01, 2014 - 08:53:25 PM »
theory is, use two, so if one breaks, you're engine can still return to idle.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: February 02, 2014 - 01:36:14 PM »
Yeah but a stuck open throttle is so much unexpected fun.
Don't ask me how I know.... different story than this though.
Offline dawerks
« Reply #11 on: June 25, 2016 - 10:44:51 PM »
Sorry to bump this.  But I have the same problem, same carb, same linkage.
How exactly does this fit together with the holley 20-7?  The linkage seems to just slide and not 'pull' the cable, does the cable also attach somewhere other than at the end?  Seems like it needs a holder for the cable itself or is that not right?
Please help!
Picture of completed unit??  And where exactly do the 2 springs attach?
Offline dawerks
« Reply #12 on: June 25, 2016 - 11:01:49 PM »
I guess I have the bracket, but how does this all fit together?  What holds the throttle cable to the bracket?
Carb and how the gas pedal line is just sitting there :)  How do I attach this?
« Reply #13 on: June 26, 2016 - 12:26:09 AM »
there is a stud standing up near the rear of the metal housing on the cable , there is a clamp piece that holds the cable housing there that you are missing
Offline dawerks
« Reply #14 on: June 26, 2016 - 12:48:13 AM »
Thank you!!  Never buy incomplete cars!!  Missing so many random little bolts and nuts.  Now I have to find what 'bracket holder thingy' goes on that stud.
