Author Topic: Firewall issue  (Read 1015 times)
Offline HP_Cuda
  • Mopar or No Car!
Firewall issue
« on: January 20, 2014 - 08:38:03 PM »
Anyone have an issue with an AMD firewall as the throttle cable I believe is supposed to snap in and mine goes in and falls out like the hole is bigger that the arms can grab.
I really don't have to have to figure out another way and yes I got this about a year ago from year one:
https://www.yearone.com/Product/1966-74-a-b-e-body/ac774
This pic doesn't even look right, it actually looks more like the hemi cable.
Anyone have an issue with this?  :clueless:
Offline anlauto
Re: Firewall issue
« Reply #1 on: January 20, 2014 - 10:04:44 PM »
Can you bend the arms out a little bit, maybe with heat?
I have an AMD firewall in my car and didn't have any issues :dunno:
Offline HP_Cuda
  • Mopar or No Car!
Re: Firewall issue
« Reply #2 on: January 21, 2014 - 07:05:33 PM »
 Yeah Alan I tried that but to no avail, might have to make some metal interor clip piece to hold it in place...
Offline CudamanTom
Re: Firewall issue
« Reply #3 on: January 21, 2014 - 07:10:01 PM »
I ran into the same thing last year although I haven't gone further as of yet.
But in my search last year, I thought I remembered reading something about a metal retaining clip kept it in place (maybe part of original design?). I read about that somewhere but can't remember.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Re: Firewall issue
« Reply #4 on: January 21, 2014 - 09:50:08 PM »
That is correct. There is a flat shaped piece of metal that slides thru on the interior side on the plastic.
Very hard to see unless you look closely you'll see the hole it slides thru.
Offline anlauto
Re: Firewall issue
« Reply #5 on: January 21, 2014 - 10:06:50 PM »
I don't think that metal strip was designed to hold it in place though...more of a safety thing if you ask me. :2cents:
Offline CudamanTom
Re: Firewall issue
« Reply #6 on: January 21, 2014 - 10:11:35 PM »
I will have to agree because looking at my SGG Cuda, it has a metal clip holding the plastic piece on the inside of the interior bulkhead. It looks original but can't verify that.
Could possibly take a pic tomorrow if needed.
Re: Firewall issue
« Reply #7 on: January 21, 2014 - 11:05:48 PM »
 :iagree:
Offline HP_Cuda
  • Mopar or No Car!
Re: Firewall issue
« Reply #8 on: January 22, 2014 - 01:13:42 PM »
That would be great because it seems I will have to make one.
Thanks!
B
Offline CudamanTom
Re: Firewall issue
« Reply #9 on: January 22, 2014 - 02:45:28 PM »
Thanks!
B
I'll take a pic in a few hours and post it.
I do remember last summer thinking a thin front end spacer might be close to working but never got around to checking. I'll dig one of those out this evening and see if it might be a possibility.
Offline CudamanTom
Re: Firewall issue
« Reply #10 on: January 22, 2014 - 05:51:40 PM »
Okay, here is what I discovered.
The first couple pics of the installed throttle cable show a piece of metal going thru the slot of the plastic housing inside the firewall. Can't say it's original or not but looks to have been in place for a while.
The next few pics show a shim for front end alignment. It may actually work as it sits in the recessed area of the housing although I didn't try it. But looking at it seems to be a pretty good way to secure the plastic piece. A very thin shim would do the trick in my mind.
Offline anlauto
Re: Firewall issue
« Reply #11 on: January 22, 2014 - 06:07:51 PM »
Your top pictures are factory original, but again I don't believe the metal strip was designed to hold the cable in place
Offline HP_Cuda
  • Mopar or No Car!
Re: Firewall issue
« Reply #12 on: January 23, 2014 - 01:23:34 PM »
Funny I spent yesterday making up something that resembles your shim
Heh kinda looks like pacman.
Offline HP_Cuda
  • Mopar or No Car!
Re: Firewall issue
« Reply #13 on: January 25, 2014 - 08:52:00 PM »
Well I decided to ditch pacman and make some pieces to keep the cable firmly attached at the firewall.
I made some stout fittings out of 20g steel and now the cable is not going anywhere. Yes I check multiple cables and they all the same as mine so somehow the firewall I got from AMD had some tooling issues. So instead of getting a new firewall...
Hopefully this might help someone in the future if they come across this problem. Again its not the way I want it but I will bet the farm that it will not come out by itself.
