Author Topic: Speedo needle  (Read 2019 times)
Offline LeeMe
  • Newbie
Speedo needle
« on: April 10, 2005 - 10:02:27 AM »
Ok,
I have a new sppedo needle but how do ya remove the old one and install the new.
Was the original needle pressed into the hub?
Thanks,
Lee
Offline 4Cruizn
  • HEMI FISH
Re: Speedo needle
« Reply #1 on: April 10, 2005 - 10:48:19 AM »
Let me be the first to welcome you to cc.com!! Let me also be the first to ask for some PICTURES!!   Love to see your ride.  OK back to the question . . . . soryy but I don't have an answer for ya but you have me curious about it.  If no one come up with an answer, I'll go tear one apart and we'll find out!!  :thumbs:  Welcome again and stick around!!  Lots of great people here!!   :beer:
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Speedo needle
« Reply #2 on: April 10, 2005 - 02:00:36 PM »
every one I ever saw was pressed on and tough to pull off
Offline MAXcuda
Re: Speedo needle
« Reply #3 on: April 10, 2005 - 04:26:41 PM »
Give Gentry a call at http://www.autoinstruments.com and he'll help you out.
Re: Speedo needle
« Reply #4 on: April 10, 2005 - 11:42:44 PM »
I just bonded the needle on top oif the old one , lots of surface area to bond to & it is aimed correctly this way
Offline miketyler
    • www.miketyler.net
Re: Speedo needle
« Reply #5 on: April 12, 2005 - 02:37:10 PM »
Yes, you cant go wrong doing it like Chryco. I emailed one of the guage guys about the repro guage sticker installation and he explained that he would mark where the guage zeroed out at, then CAREFULLY dremel cut the old needle from the base then rebond it after the decal was installed.
If your speedo face is weathered, you may want to buy one of the decal kits and reface the guage before you install the needle
Let us know how it goes
« Last Edit: April 14, 2005 - 10:51:55 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline revitup
  • Newbie
Re: Speedo needle
« Reply #6 on: April 15, 2005 - 04:03:26 PM »
Hey dude, if your speedometer needle is broke on your challenger, replaceing the needle isn't the solution.  I learned lately that the speedometer needs rebuilt.  Real technical and I don't understand it all, but I believe it.  Sorry to bring the bad news.  Mine is broke also.  Saving my $ up!
Re: Speedo needle
« Reply #7 on: April 15, 2005 - 04:39:49 PM »
I changed 1 last year & it works perfectly
Offline Katfish
  • 70 Challenger
Re: Speedo needle
« Reply #8 on: April 16, 2005 - 02:56:50 AM »
I also had a broken needle.  Sometimes you can just replace the needle, but typically the real problem is the plastic bushing in the tail shaft (part where speedo cable goes in) is worn out.  This causes the needle to shake and eventually breaks it.
I learned all this the hard way, crappy vendor replaced needle, said everything was fine.  It broke almost immediately.  Had to have bushing repaired and 2nd new needle done at another place, $200!
Offline GregGarner
Re: Speedo needle
« Reply #9 on: November 08, 2005 - 09:58:38 AM »
Where did you get the new speedo needle from?
GregGarner
www.rt-eng.com
Home of the mopar tach and clock repair kit
Re: Speedo needle
« Reply #10 on: November 08, 2005 - 10:32:15 AM »
I think I got it from Performance car graphics
