Dumb luck
Author Topic: Dumb luck  (Read 1081 times)
Offline 360FISH
  • BS23H3B567746
Dumb luck
« on: January 21, 2014 - 01:56:20 AM »
Hey all…  if you’ve followed anything I’ve done, you’ll know I’m a novice when it comes to knowing how things are engineered or what certain things should look like on my car.
Well I opened a couple new chapters in my ’73 Cuda follies over the holidays…
1st – while messing around with the car I realized my 360 is not balanced!  The torque converter is missing the weights.  I found this when I switched to a harder tranny mount and my car started shaking like crazy.  The old rubber mount was absorbing the shock.
After switching out the torque converter the car runs so much smother it’s like another car.  Amazing!
2nd – after driving the heck out of the car the last year I was getting a noise that sounded like bearings in the rear axle needed replacing.  No biggie except I learned these need to be pressed into place so I wouldn’t be able to do these at home.
I took the fish to a shop and later received a call with the final report… yep I needed bearings, seals and clutches the guy said… “and your posi will start to work again”.
Funny…  I didn’t know I even had a posi!   :bigsmile:
I sure can feel the difference too.
Yes dumb luck!
 :cheers:
Alan
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline ChallengerHK
  • Moderator
Re: Dumb luck
« Reply #1 on: January 21, 2014 - 02:58:47 AM »
Cool to have posi. I'll be interested in hearing about the outcome with your motor.
- Han Solo, Star Wars
Offline 67vertman
  • Member since 9-23-2005
Re: Dumb luck
« Reply #2 on: January 21, 2014 - 01:23:56 PM »
"dumb luck" is the best kind of luck.   :smilielol:
Glad to hear your enjoying your car more than ever.
Offline anlauto
Re: Dumb luck
« Reply #3 on: January 21, 2014 - 01:29:46 PM »
SURE GRIP  :burnout: :woohoo:
Offline 360FISH
  • BS23H3B567746
Re: Dumb luck
« Reply #4 on: January 21, 2014 - 03:58:11 PM »
FYI - the rear main seal immediately started leaking after the tranny mount change.  I'd bet it was buggered when it started to take the shock vs. the old tranny mount.   It was only unbalanced like that for a few minutes before shutting it down and deciphering the issue.  When the rear main was replaced the bearings were inspected and looked okay.  Have only driven it a short while since and just a small (residual?) drop of oil seen.
Yes...  feels very different driving the car now...  the rear feels like it squats down on launch and you can feel it grip when going around a sharp turn.   Pretty cool.
Re: Dumb luck
« Reply #5 on: January 21, 2014 - 10:12:46 PM »
  • Moderator
Re: Dumb luck
« Reply #6 on: January 21, 2014 - 11:20:55 PM »
Technically I think that's correct. In practice, I'd guess about half of the people talking about them call all limited slip differentials "posi." Kind of like how all copies from a photostat machine are "xeroxes."
