initial timing
Author Topic: initial timing  (Read 1914 times)
Offline rattlesnake
  • Rattlesnake
initial timing
« on: January 23, 2014 - 12:18:37 AM »
What is meant by Mallory saying their distributor has 24 degrees of initial advance timing built into their distributor? Could this be too much for some engines causing problems when starting?
keep honking I'm reloading
Re: initial timing
« Reply #1 on: January 23, 2014 - 08:45:02 AM »
Hard to say , it could mean that with the timing set @ 36 * total the initial timing will be @ 24* with a 12 degree total curve , I have found more like 16-18* at idle with 36 total seems to work well but you can try it as is
Offline rattlesnake
  • Rattlesnake
Re: initial timing
« Reply #2 on: January 23, 2014 - 10:14:10 AM »
What the installation sheet says is "all Mallory unilite distributors are shipped with 24 degrees advance on the distributor" When I have the total timing set at 36 degrees the engine runs good when warm and throttled up. On cold start at idle it still wants to pop through the exhaust, I thought I had this solved but it isn't. I am wondering if the culprit could be too much initial advance at the distributor.
Re: initial timing
« Reply #3 on: January 23, 2014 - 11:22:59 AM »
Sounds like there is 24 degrees of mechanical advance built into the distributor.  If you have the total timing set at 36, then you have 12 initial.  Try bumping up the initial to at least 15 and see how it idles.  Worry about the total timing after you get the initial set where the engine likes it.  You might have to open up the distributor to decrease the mechanical advance.
« Last Edit: January 23, 2014 - 11:24:40 AM by burdar »
Offline jimynick
Re: initial timing
« Reply #4 on: January 23, 2014 - 10:06:47 PM »
:iagree:  Popping through the exhaust is usually a sign that it's too retarded and it'll cough through the carb if it's too far advanced.
Offline rattlesnake
  • Rattlesnake
Re: initial timing
« Reply #5 on: January 24, 2014 - 03:39:33 PM »
Just FYI if you ever run into this issue. The Mallory unilite distributor installation instructions stated it was preset from the factory with 24 degrees advance. I have had this popping through the exhaust since I started the motor after rebuild, but it would only do it when cold. It would gradually go away as it warmed up. It never made any sense to me. Even with the total timing set correctly it would pop through the exhaust on initial start up when cold. I tried everything from resetting timing numerous times thinking I had made a mistake the first time. Replaced carb gaskets, resetting valve lash three times. I tested every component I could think of. After reading about the unilite distributor being preset from the factory at 24 degrees, I thought that was a bit much. I was always told I wanted as much timing as I could get on the crank and a minimal amount on the distributor. So..... I tore the distributor down and set the distributor advance timing at 16 degrees. The dang thing started right up and ran like a champ right out of the gate. I was then able to reset total timing at 34 degrees at about 2500 RPM. It runs great and starts right up. Hopefully this is the permanent fix for this issue.
Offline footin70rt
Re: initial timing
« Reply #6 on: January 24, 2014 - 06:27:04 PM »
The following was stolen from a "cough" Chevelle forum but has some really good info on timing.
______________________
The following two articles review the basics of distributor tuning quite well and have worked for years and years and are based on sound engineering principals. I thought it would be helpful for some to review these prior to hacking up their distributors. Hacking up your distributor to compensate for a poorly tuned, misapplied or defective carburetor is not very sound engineering, for a street application or otherwise.
Here's an interesting article on vacuum advance written by a GM engineer:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
__________________
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Re: initial timing
« Reply #7 on: January 25, 2014 - 07:45:35 AM »
Interesting read but I don't quite understand the above statement. I can see how the vacuum drops low when you first open the throttle, but after you are at 60mph, your vacuum is higher right? So you would have 10-12* initial, plus your full mechanical - say 24* and vacuum then adding more? Probably over 40* total. I must be misunderstanding something? :clueless:
