Author Topic: what and how are you painting new floorpans?  (Read 962 times)
Offline barracuda7199
  • needs a resto but having to much fun right now
« on: January 23, 2014 - 07:52:46 PM »
been away for a while mostly been hunting but thats over now and back to the cuda!
decided to start removing the rust and bad patch job we did back in 99. I mostly have my rusty floorpan removed and i been wondering what has everyone been using to cover the new floorpans and inside the frame rails? i am not concerned with originality just want it to last! here is a few pics of what i started with. i will have the floor out tomorrow evening.
« Last Edit: January 23, 2014 - 07:55:11 PM by barracuda7199 »
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline shawge
  • Zoiks!!
Re: what and how are you painting new floorpans?
« Reply #1 on: January 23, 2014 - 09:11:54 PM »
It looks like a lot of swiss cheese.  My trunk was the same way when I got my car.
When I had access to exposed frame rails, I cleaned them out as best I could, applied a metal treatment (something with phosphoric acid), and brushed on a couple of coats of 2 part epoxy paint.
- Jerry
Offline jimynick
« Reply #2 on: January 23, 2014 - 09:46:43 PM »
:iagree:  Yep, epoxy is your friend AND you can/should also spray something like Krown rustproofing in and on the rails as well. I know the local Krown guy and mine's going to take a bath in it whenever I actually get the old gal done! Good luck and don't forget you can bond the floor onto the braces as well and seam seal everything!  :2cents:
« Reply #3 on: January 23, 2014 - 10:01:25 PM »
I used 3M Rust Fighter inside the frame rails.
It's like an emulsified oil/wax mixture.
See the pictures I did using a undercoat gun.
Watch your PSI. Not too much needed.
Tip for it can be fabbed or bought from Eastwood.
http://www.cuda-challenger.com/cc/index.php?topic=71221.msg726711#msg726711
« Reply #4 on: January 24, 2014 - 07:16:16 AM »
 :cheers: I'm guessing I need to scuff the EDP on the bottom of the pan and paint it. Brush on bed liner should be a good to use.
Brandon
Offline anlauto
« Reply #5 on: January 24, 2014 - 07:22:37 AM »
Car should be sand blasted and properly cleaned first. :2cents:
