Author Topic: Question on fender installation  (Read 1246 times)
« on: January 24, 2014 - 09:51:01 AM »
When I removed my fenders to weld in the US Cartool cowl braces I noticed some type of seam sealer between the fender and the inner fender? What should I use when I reinstall ? I wire wheeled it all off to check for rust and there was none. :2thumbs:
 :wave: Thanks Brad
Re: Question on fender installation
« Reply #1 on: January 24, 2014 - 04:37:10 PM »
Brad,
  I know what you are talking about. I'm wondering if some modern day silicone caulk from a hardware store would work? All it is there for is to keep water from coming up through the seem and into the engine bay.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #2 on: January 24, 2014 - 06:46:18 PM »
Couple of options, a seam sealer, strip calk or just a thin foam gasket. the strip calk is easy to use and comes off somewhat easy if you ever need to redo it.
http://www.amazon.com/3M-31050-Flexible-Strip-Length/dp/B00383PX4Y/ref=sr_1_2?ie=UTF8&qid=1390607155&sr=8-2&keywords=3m+strip+calk
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Edison1970
« Reply #3 on: January 24, 2014 - 08:21:13 PM »
When I took my challenger fenders off in 1980, they had a black tar like ribbon between the mounting surfaces. Back then, I bought the same stuff from a paint and body supply shop.
« Reply #4 on: January 24, 2014 - 08:48:08 PM »
Thanks guys! :2thumbs:
Offline Challenger6pak
« Reply #5 on: January 24, 2014 - 09:55:51 PM »
I would stay away from using foam.  It will hold water and create rust.
