Author Topic: 73 Cuda Rear Sway Bar  (Read 1129 times)
Offline cuda lover
« on: January 24, 2014 - 02:42:57 PM »
Does anyone have info on rear sway bar for 1973 cuda
what was original bar diameter?
recommendation for replacement (maker / part number)?
recommendation for hangers?
pictures of how it hooks up
any help appreciated
Cuda Lover
CUDA Lover
Offline EB3-GranCoupe
  • BP23 U0B
Re: 73 Cuda Rear Sway Bar
« Reply #1 on: January 25, 2014 - 09:15:52 AM »
Check out these guys, it's where I got mine:
http://www.firmfeel.com/swaybarsrear_e.html
Sorry I don't have any of the original specs, but they probably do.
Offline JayBee
« Reply #2 on: January 25, 2014 - 10:28:29 AM »
I measured the diameter of the one in my basement using a digital caliper in different spots on the bar and came up with an average of .74 inches. It was originally probably 3/4 of an inch, and the discrepency is due to the rust erosion.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline cuda lover
« Reply #3 on: January 25, 2014 - 12:20:56 PM »
will do thanks, I am working with them on the front steering components.
also thanks JayBee for the measurement
Cuda Lover
CUDA Lover
  • BP23 U0B
« Reply #4 on: January 26, 2014 - 04:53:03 PM »
I'm pretty sure the 71-74 rear sway bars are the same as the TA/AAR set-ups.  3/4 inch diameter; the firm feel unit is the same as far as I know. good luck!   :cheers:
Offline TA Wanted
  • Im a Mopar Addict
« Reply #5 on: January 27, 2014 - 11:46:24 PM »
Mine is an original piece on the 73 and it also is .75 diameter. Finding replacement bushings was the hard part. I will be needing another set when I get the TA......next month
Dennis
« Reply #6 on: January 28, 2014 - 10:17:41 AM »
New bushings for that application are not available.  It wasn't supposed to be a serviceable part since the straps are welded to the frame brackets.  Aftermarket pieces use bolt on straps.  I had to find a nice pair of original bushings, cut the straps off and re weld them onto the frame brackets.
