Author Topic: Who makes the best replacement fender for a 70 Challenger?  (Read 7896 times)
« on: January 25, 2014 - 05:33:08 PM »
How makes the best fitting fenders? Hows the body lines match up? Fit and finish?
I'm guessing AMD?
Offline farmboy70
Re: Who makes the best replacement fender for a 70 Challenger?
« Reply #1 on: January 25, 2014 - 10:16:05 PM »
I have installed AMD and had no problems.
Dave
Offline anlauto
« Reply #2 on: January 25, 2014 - 10:40:02 PM »
What'd you do Brad ? :nono:
« Reply #3 on: January 25, 2014 - 11:03:19 PM »
Oh nothing yet. I was considering buying new fenders to modify for bigger rims/tires and putting away my original stock rust free ones? Just considering my options?
« Reply #4 on: January 26, 2014 - 11:51:25 AM »
How big you wanna go? I got 255's up front and Brian has 275's. Both without fender mods.
« Reply #5 on: January 26, 2014 - 12:18:17 PM »
I still have the front end sheet metal off my car and was just doing some "wondering" I finally have the funds saved up for new tires and rims and would like to fit a 10" rim up front. I was "thinking" of cutting the fender where the flair starts and widening it maybe 2" ? :dunno: Interested to see if one could or what would be nessesary to fit a 295 or larger up front. Keep in mind I don't have a stock e-body front suspension. I can easily fit 8" rims in there but anything bigger I think it will hit the fender. I have 7" rims up front now with a 1/2" spacer to give more clearance on my lowered tie rod set up. ( I could get away without the spacer but I was just being cautious) I'm not sure yet if I could get the tie rod up into the rim on an 18" rim yet? I could adjust it up but that would mess up my bumpsteer some. Not sure what would be better wider tires at the expense of bumpsteer? I have one of those Percy's wheel tools but haven't played with it yet? http://www.jegs.com/i/Percys/760/01201/10002/-1
I figure if your going to cut a fender..... might as well fit the biggest rim/tire in there you can get? No point in screwing around? :aarg:  If I do cut and mod a fender I still want to be able to use the wheel well trim....?
 Just thinking ..... nothing for sure yet. It's winter and I'm bored.... and my mind is working? :thinkerg: :lol:
« Last Edit: January 26, 2014 - 12:23:00 PM by brads70 »
« Reply #6 on: January 26, 2014 - 12:27:31 PM »
Dave
Thanks!  :wave:  I was leaning towards AMD . They are backordered and I have no idea when they will be available again? :dunno:
« Reply #7 on: January 26, 2014 - 02:56:14 PM »
Why not go with fiberglass?  Less money, less weight, easier to modify.   :2cents:
« Reply #8 on: January 26, 2014 - 03:00:51 PM »
Who makes them? :clueless:
Offline ChallengerGary
    • Challenger Gary
« Reply #9 on: January 26, 2014 - 03:05:42 PM »
I spoke with AMD a few days ago about the fenders and at the time I was told probably mid March.  I'll call again tomorrow and see if they have a more firm date.  BTW - I am an AMD distributor when you are ready to order.
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline moprr
« Reply #13 on: January 26, 2014 - 08:20:16 PM »
Amd would be alot of money for something that you will be cutting up.  Those fiberglass seem like a good start you just need to make 1970 marker lights fit as these fenders have newer ones.
« Last Edit: January 26, 2014 - 08:23:20 PM by moprr »
« Reply #14 on: January 26, 2014 - 11:16:34 PM »
Hmmmm.... you thinkin' 'bout goin' faster in the Carlisle autox this summer?  :bigsmile:
Trying to make a nose heavy big block Challenger not 'plow' into corners?
