Author Topic: American powertrain profit TKO600 kit (auto to manual)  (Read 6286 times)
Offline anlauto
Re: American powertrain profit TKO600 kit (auto to manual)
« Reply #15 on: January 30, 2014 - 10:00:10 PM »
Alan, ordered my TKO 600 and kit today from American powertrain today!!
Sent from my iPad using Tapatalk
Did you ask about time frame? Just curious what they told you....they told me 4 weeks...
Offline twalker
« Reply #16 on: January 30, 2014 - 10:13:43 PM »
Yep, told me 4 weeks as well.  They've been good to deal with so far, better than hurst - thus I gave them the order.
Offline anlauto
« Reply #17 on: January 31, 2014 - 06:24:27 AM »
I called both and thought the same thing too. :worshippy
Offline tommyg29
« Reply #18 on: November 16, 2014 - 02:22:11 PM »
 :popcorn:
Any word on the install and how it went.
 :burnout:
Offline anlauto
« Reply #19 on: November 16, 2014 - 02:24:17 PM »
It was not a direct bolt in as described. To get the proper driveline angle, the transmission mount and the floor had to be altered just as other people have done. :banghead:
Offline tommyg29
« Reply #20 on: November 16, 2014 - 09:10:11 PM »
Too bad.
I saw this kit advertised in Hot rod magazine for $1450.
Offline twalker
« Reply #21 on: November 16, 2014 - 09:14:07 PM »
Here are a couple pics of my install, you will see I had to cut and make room both in the tunnel and the cross member.
« Reply #22 on: November 18, 2014 - 10:19:40 AM »
Too bad.
I saw that too. But when you go and price it out at the website, I think the 1450 is just the trans with no installation kit. Once you order both you are over $3000.
Offline scarpent1
« Reply #23 on: November 18, 2014 - 01:51:11 PM »
The $1,428 (for E Body) is without the transmission.  From their website:
Kit includes:
Streamlined TKO Main Case - For maximum tunnel clearance (transmission sold separately)
ProShift3 Shifter Mechanism for E-body - Provides OE shift position
3.5" Seamless DOM Driveshaft - Race balanced, solid u-joints
Driveshaft Slip Yoke - Cryogenically hardened
Bolt-In Cross Member - Black powder coat, uses original bolt holes
Isolator Mount - Polyurethane
Speedometer Solution - Mechanical or Electronic
Conversion Pilot Bearing - Works in manual and automatic cranks
Conversion Release Bearing - Compatible with OE clutch fork,
Weatherseal Reverse Light Harness,
Tunnel Patch and Template (small),
Hardware, Complete Instructions and Industry Leading Warranty,
24-Hour Customer First Technical Support
Transmission sold separately
NOTE: Requires engine specific bell housing. $50 release bearing delete when using hydraulics.
Offline Kevin71
« Reply #24 on: February 10, 2015 - 03:03:13 PM »
Did the trans sit right down on top of the trans cross member or did you have to shim it up to get the right angles?  If so how much.
