From memory the basic gauge set is $995.00, it cost me an additional $240.00 or something to have the font, lines etc changed. I just needed to add some extra line arc's under the numbers on my fuel, volts, oil and temp numbers, they look a little bland. I purchased add on temp senders for trans and engine oil as well so all up it was roughly $1400.00. BUT I also had to then get the rallye bezel and fascia from PG Classics, so throw in another few hundred as my Cuda only has the std dash. as I see it lets call it a smidge over $2K. It would have cost me that easily had I bought the OEM style gauges, but I wouldn't have all of the other additional options that the DD dash has and it all just drops into place, wire it up and done. Yep I could have bought gauges and built my own basic gauge set but I dont have that time available. Im very happy with the result. I can program the DD to tell me when I need to change the oil, I dont have to find and pay for speedo gear drives to match my diff ratio and tire combo, I will have MPH on the needles and KPH in the digital read out (we are KPH down here), I will have integral shift lights, AFR, and so on without having to clutter my dash with additional gauges, they are back-lit so I can finally see the gauges at night rather than the dim green glow
