Author Topic: help with carbureted 6.4 hemi in 70 challenger  (Read 9567 times)
Offline cardfb45
« on: February 01, 2014 - 11:55:59 AM »
im building a 70 challenger convertible resto mod and have been kicking around engine ideas. i decided on a gen 3 hemi and really like the new 6.4 but i'd like to go with a carburetor instead of efi to keep it a little more simple. has anyone here done this and can give me some advice on what they used? should i get a short block and build it from there? or am i better of starting with a motor out of a wrecked srt8.
Adam
1970 challenger convertible pro touring project
2004 ram 2500 5.9 cummins
Offline Oldschool
  • Member Since 9-05-06
Re: help with carbureted 6.4 hemi in 70 challenger
« Reply #1 on: February 01, 2014 - 01:46:22 PM »
I think INDY has an induction setup for those engines. They sell new intake manifolds and carbs for those.
http://www.indyheads.com/images/28.cat2014.pdf
Ken  --  In Georgia
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #2 on: February 02, 2014 - 12:52:34 AM »
You can also buy the complete crate motor carbureted from mopar
http://www.bpeusa.com/P5153603_P5153604_P5153605.asp
« Last Edit: February 02, 2014 - 12:57:56 AM by moparman82 »
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #3 on: February 02, 2014 - 04:29:58 PM »
I not sure if its much simpler with a carburetor though, I believe you still need a special harness and engine controller to run it.  I saw some where that somebody converted a HEI distibutor to the front timing cover to run the ignition
Offline cardfb45
« Reply #4 on: February 03, 2014 - 11:02:01 PM »
That bp crate looks nice but seems a bit pricey at almost 18,000. do i need a computer to run the ignition or is it just a module? or if i use the hei setup that would eliminate all my elictric complications right or am i missing something?
Adam
Offline cardfb45
« Reply #5 on: February 03, 2014 - 11:12:09 PM »
also that intake from indy looks like it would work great but I've heard so many bad reviews about indy that it kinda makes me hesitant to use their parts
Adam
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #6 on: February 04, 2014 - 01:14:32 AM »
Saw this on horsepower tv awhile back works with efi and carbs they also used the mod man intake from Indy hope this helps and they used the msd hemi 6 for ignition worked well
http://www.summitracing.com/parts/msd-6013?seid=srese1&gclid=CJuhnqTosbwCFY49QgodmVEA0A
Cuda James
« Last Edit: February 04, 2014 - 01:56:51 PM by calicuda70 »
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
« Reply #7 on: February 04, 2014 - 07:43:29 AM »
That has the old school look for sure...  :2thumbs:
Offline cardfb45
« Reply #8 on: February 04, 2014 - 06:26:36 PM »
thanks for the input guys. this site has been a great resource
Adam
Offline Modern Muscle
    • Modern Muscle Performance Group
« Reply #9 on: February 16, 2014 - 01:24:22 AM »
Just a FYI that will not work on the 6.4 VVT Motors
Offline calicuda70
« Reply #10 on: February 16, 2014 - 02:09:19 AM »
So what can we use for ign. System on a 6.4
70 Challenger 360
Offline cardfb45
« Reply #11 on: February 17, 2014 - 04:54:57 PM »
I just looked back and saw that it doesnt include the 6.4 and looked around and dont see any options for a 6.4 does any no of another option?
Adam
« Reply #12 on: February 24, 2014 - 10:54:43 PM »
You will not be able to run a carb setup with VVT personally I do not know why you would want to, You would lose a bunch of HP and fuel economy just by doing the swap.
With that said we have a plug and play system that can control the engine if you are planning on keeping EFI.
http://www.modernmuscleperformance.com/product/dbw-engine-management-vvt-09-and-newer-hemi-auto-545rfe
Offline cardfb45
« Reply #13 on: February 26, 2014 - 11:57:29 AM »
 Why would I lose HP with a carb set up? A lot of the 6.1s I've seen seem to get more with a carb that's also easier to tune. I mostly liked the idea of a the carb to simplify things instead of having to modify the tank and fuel lines and needing to have a whole computer setup to run the motor. That and a six pack would look much cooler than a throttle body. That being said I don't know much about these motors so y does the vvt change how the plugs are fired?
Adam
« Reply #14 on: February 26, 2014 - 07:36:54 PM »
The Power loss we have seen for carb setups is because of the intake change (runner lengths) and efficiency of EFI compared to carburetors, As for tuning we developed as system that is plug and play that do not require any tuning on the EFI system. As for using the the other engine managment systems out there like fast or mega they cannot control the Variable timing or read the new Crank trigger
