Hey guys I'm hoping someone out there has experienced what I'm experiencing and can give me some advice. I've got a 70 Chally with manual brakes and 4 wheel disc. The mc, proportioning valve, and rear calipers came from Dr Diff. Front brakes are stock disc that I got from Rock Auto. I redid the lines as part of the rebuild. It's a brand new system on a car that doesn't run or drive yet.
My problem is that I cannot get consistent pressure on the pedal. First pump goes to the floor even after power bleeding. If I pump it 4 or 5 times I get good pressure, but when I stop for 15 seconds and try again it goes to the floor. If I pinch the left front hose I get good pressure on the first push. If I pinch the right front hose I get mediocre pressure.
I've used a power bleeder to bleed the system, I've plugged the mc and tested it, I've replaced the left front caliper and hose. Both calipers work great when there's pressure in the system.
I can't think of anything else to replace or test. Any ideas?
