after sleeping on it I think one of the carbs (probably the front because some fuel did come out when I removed that sight plug) was stuck, and the electric pump just filled the cylinders and then then the intake manifold and into the vacuum line to the brake booster, and probably some if not a bunch into the crankcase.
Correct me if Im wrong but what I will do next is remove all spark plugs, drain the oil, try to suck any fuel out the brake booster with a tube, and then put some cheap oil in the engine, and then turn the engine over a few times without plugs (and maybe check compression while Im at it) with the ignition disconnected and electric fuel pump off to circulate a little oil with some flushing action. Then put plugs back in, reconnect everything and try to start it up. And VERY soon after change the oil again.
Of course, I need to also check and repair the carbs.
Sound OK?
PS
What does holly charge for their six pack rebuild/restore service?
