Author Topic: New steering column inner shaft 70 Barracuda  (Read 530 times)
Offline moparstyle
« on: February 02, 2014 - 11:11:52 PM »
Kind of stuck at the moment as my steering shaft is trashed. The splines are bad, it has been extended (?) and has several welds. Shortly, needs replacement.
I have placed an ad but i guess its hard to find one.
Next option would be to make a new shaft. There are universal ones with correct diameter but i would then need to replace the coupling at the steering box with a u-joint (if i am not able to press the pin out and reinstall in the new shaft).
If i go that way, how about the splines for the steering wheel / crush can? Machine shops in general, are they able to cut new splines in a bare shaft (included the master spline in the crush can)?
What is your thoughts? Hopefully someone had the same experience.
« Last Edit: February 02, 2014 - 11:14:46 PM by moparstyle »
72 Challenger, 440 stroker, 727 (70 clone)
70 Barracuda Gran Coupe
And on the side:
67 Pontiac GTO
63 Lincoln Continental
Offline Moparparts
Re: New steering column inner shaft 70 Barracuda
« Reply #1 on: February 02, 2014 - 11:16:56 PM »
I have some good used shafts. Is it for power or manual steering? PM or e-mail me
