Author Topic: 6-Pack Carb Identification  (Read 2222 times)
Offline onebadfish
« on: February 06, 2014 - 12:00:59 AM »
I took my intake off the 440 today and was wondering if anyone knows what these carbs came off? Rear carb - 1139 LIST 4393, Center carb - 1209 LIST 4391, Front carb - 1139 LIST 4394.
I am planning a rebuild on each as well as Promax base plates.
Offline Cuda Cody
  • Vancouver, WA
Re: 6-Pack Carb Identification
« Reply #1 on: February 06, 2014 - 12:37:00 AM »
1969 A12 Manual
Offline onebadfish
« Reply #2 on: February 06, 2014 - 12:43:11 AM »
Thanks Cody. Wonder if the intake is 69 vintage as well? Anyway to tell?
Offline anlauto
« Reply #3 on: February 06, 2014 - 06:47:36 AM »
Is the intake aluminum or cast iron would be a good indication. :2cents:
« Reply #4 on: February 06, 2014 - 06:57:14 AM »
The date code is the 1139 & 1209 , 113 is the day , 9 is the year so it looks like a matched set
 the lower # carb should be in front 4393 , rear is 4394 .
Offline onebadfish
« Reply #5 on: February 06, 2014 - 01:29:41 PM »
The intake is aluminum but can't find any numbers depicting a part number?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: February 06, 2014 - 01:57:17 PM »
I have a cast iron intake to make your setup original if you are interested.
Date coded for 69
Offline anlauto
« Reply #7 on: February 06, 2014 - 02:13:38 PM »
Date coded for 69
 :clueless: 19691/2 A12 cars came with an aluminum intake from the factory as well as some early 1970 V code cars. :2cents:
That's why I asked if the intake was aluminum because, as Cody said, the carbs are correct for an A12 car. :2cents:
Offline onebadfish
« Reply #8 on: February 06, 2014 - 02:24:48 PM »
That's correct. All A12 cars had aluminum intakes and I believe that was ma mopars intent however Edelbrock couldn't make them fast enough so they resorted to cast mid 70. That's my understanding anyway?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: February 06, 2014 - 02:35:54 PM »
Well just like Alan said "You learn something new every day!"
Pretty cool to see an aluminum intake from the late sixties.  :2thumbs:
