Okay, just spent the past hour searching for info on installing my rear window. Think I got most of my questions answered except what kind off window adhesive to use. Several threads talked about using 5/16" butyl tape and some recommended against it and said to use auto glass sealant instead. So what's the current recommendation, butyl tape or glass sealant? Also, if it is butyl tape, do you need to use a sealant between the edge of the glass and window frame, especially on the bottom so water won't pool, or is the butyl tape sufficient?
Thanks
