Author Topic: Convertible top hydraulics troubleshoot  (Read 1044 times)
Offline Trifecta
« on: February 09, 2014 - 02:27:07 PM »
Have a convertible top that comes up only with assistance after several years of use.  Seems clear its in the hydraulics, failing piston? fluid flush and refill?  Not much out there on this forum as to how I should proceed.
Anyone out there with some experience servicing the hydraulics on a vert that can point me to the right right direction on this process, your insights would be greatly appreciated.
Offline CudamanTom
Re: Convertible top hydraulics troubleshoot
« Reply #1 on: February 09, 2014 - 02:39:47 PM »
Welcome to the C-C.com forum.
Sounds like to me the pump is wearing out. You might try replacing the fluid with new fluid first and see if that helps. But the pump sounds like the problem IMHO.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Trifecta
« Reply #2 on: February 09, 2014 - 03:01:54 PM »
Thanks Cudaman - I've been lurking for some time.  This forum is a great resource.  System takes F-type hydraulic fluid correct?
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #3 on: February 09, 2014 - 04:05:45 PM »
Automatic trans fluid - Type F or Dextron - I don't think it matters which one you use with the 'vert pump.
Make sure the pump is topped off with fluid.
You don't have any fluid leaks do you? Those plastic lines get brittle with age and can crack. Give the pump, lines and actuators a good visual inspection and make sure they are not leaking.
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline wiging19
« Reply #4 on: February 09, 2014 - 09:39:10 PM »
That was my experience when my top didn't come up.  The previous owner never checked the level.  I think I replaced all the lines with tubing used in aquariums.  Looked exactly the same except not yellow.
Offline Trifecta
« Reply #5 on: February 13, 2014 - 06:15:52 PM »
Thanks for the comments.  They are helpful.  So upon removing the sear it is clear that the unit has been leaking although its very slight so hard to tell the location of the leak at this point.
Filled the resevoir - now how do you bleed the air out of the system?
Offline Finoke
« Reply #6 on: February 13, 2014 - 06:42:01 PM »
This is a good supplier for parts as well as instructions for how to bleed...
http://www.hydroe.com
Offline CudamanTom
« Reply #7 on: February 13, 2014 - 09:18:02 PM »
This is a good site to go to.  :bigsmile:
Offline hemiken
« Reply #8 on: February 14, 2014 - 08:55:24 PM »
 :popcorn:
Offline Trifecta
« Reply #9 on: February 15, 2014 - 11:43:37 AM »
 :bananasmi Back in service.  Appears the gasket between the reservoir and the motor may have been seeping.  I tightened it a bit, filled with fluid, bled out the air.  I'm going to leave it open for a bit to see if it starts to seep again.  Can you replace the gasket between reservoir and motor?
Offline Finoke
« Reply #10 on: February 15, 2014 - 02:18:46 PM »
Yes, I believe they sell the gasket.
