My map light works when I first got my car a year ago and quit shortly after. I changed the light bulb at that time but still nothing. So I finally got up my butt last week to try to find out what the problem is. There is no voltage when I measured the harness with the ignition key on. From the wiring diagram, there appears to be a time delay relay in there but I could not find it under the dash. May be that is bad? I assume it is not the same as the turn signal or the flasher relays. Anyone can tell me where it is under the dash and how to test it. BTW, all my interior lights works except the light by the ignition key which I have difficulty inserting the bulb.
