Author Topic: New paint job, but when I washed my car my feet got wet under the dash  (Read 1054 times)
Offline EMCD
Am I missing some drain lines that keep water from coming into the cabin? I am missing the hood cowl weather stripping, is that an easy find and replacement piece?
Offline johannes
Re: New paint job, but when I washed my car my feet got wet under the dash
« Reply #1 on: February 15, 2014 - 04:42:46 PM »
The water that that enters the room where the wiper mechanism is mounted, will drain the down the bulkhead....test this using a garden hose. So not worry about gaskets
My guess is you have some rotten metal "under" the aft upper part of your front fender...
Can look for this through your windscreen... see pic
Offline EMCD
« Reply #2 on: February 15, 2014 - 06:35:36 PM »
I don't think that could be possible. I just had the car restored. The only rust I had on the car was in the rear qtrs. any other possible origins for the leak?
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: February 15, 2014 - 06:37:05 PM »
Get two guys and a hose.  You'll find it pretty quick.
Offline anlauto
« Reply #4 on: February 15, 2014 - 06:40:19 PM »
Even better if you lay inside looking up under the dash with a flashlight............and goggles :rofl:
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #5 on: February 15, 2014 - 07:44:14 PM »
Air vents and windshield channel are also spots for rust/leaks. If you just had the car restored I would be bringing it back to whomever did the work!!!
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #6 on: February 16, 2014 - 07:47:38 PM »
Keep us posted.
Daniel
www.ebodyproducts.com
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #7 on: February 16, 2014 - 08:10:13 PM »
Mine did the same thing. When they did the body work they eliminated the cowl vent drain on the firewall near the fuse block. The cowl vent was flooding causing water to leak inside the car.
Offline EMCD
« Reply #8 on: February 16, 2014 - 09:18:17 PM »
Cool. I saw the car completely stripped and the only rust on the car was behind the hood hinges, the outer wheel wells and lower quarters. So, it's my quess that the cowl vent tube is missing.it only came down in one spot, like under a faucet. It landed directly on top of my left foot.
Offline Cuda Cody
  • Vancouver, WA
« Reply #9 on: February 16, 2014 - 09:28:44 PM »
There is not a Cowl Vent Tube.  Take the Cowl covers off and look down in there.  Make sure the drain hole is not clogged nor is there a rust hole.  Water sits in there and it can rust out I've attached a photo of the firewall that someone had posted years before and it shows the Cowl Drain.  My guess is it's clogged.
Offline anlauto
« Reply #10 on: February 16, 2014 - 09:29:07 PM »
"Cowl vent tube" ? What kind of car are we talking about ? A & B Bodies have wiper pivot seals that leak into the car. :dunno:
Offline jimynick
« Reply #11 on: February 16, 2014 - 09:49:42 PM »
Since it landed on your left foot, it may be the rubber seal that seals the heater box to the cowl above the little door that you can open for a breeze when you're driving. It's basically an oval and seals the standpipe flange in the cowl off. There'd have to be a fair bit of water going in and the drain either not working or bunged to run over the standpipe flange as it's about 3/4" high. Like the man said, get in and under and get a bud to run a hose over it and then you'll know for sure. Good luck
Offline EMCD
« Reply #12 on: February 16, 2014 - 09:57:10 PM »
Cool. Thanks guys. It never leaked before the restoration.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #13 on: February 16, 2014 - 11:34:20 PM »
Here is a few shots of your left foot area, both inside and outside with everything removed.
« Reply #14 on: February 16, 2014 - 11:34:45 PM »
And one with the vent installed
