Author Topic: New wiring harness  (Read 1718 times)
Offline EMCD
New wiring harness
« on: February 15, 2014 - 06:59:18 PM »
How difficult is it to install a new wiring kit from painless wiring? The car is fully assembled.
Offline anlauto
Re: New wiring harness
« Reply #1 on: February 15, 2014 - 07:02:14 PM »
Why ?
Does your car have a LOT of non-factory modifications ?
Otherwise I see no reason to open youself up to so many headaches, when brand new "plug and play" wire harness's are available at a reasonable price :2cents:
Offline EMCD
« Reply #2 on: February 15, 2014 - 07:17:07 PM »
100w stereo, dual extrication fans, MSD box and coil. My dash started to smoke this morning  and I'm worried about a 41 year old wiring harness cannot handle the changes. Also, I updated the alternator to a 70 amp unit. Are my worried unfounded and do I just need to chase down my potential short?
Offline anlauto
« Reply #3 on: February 15, 2014 - 07:26:00 PM »
Personally, with every car I restore, I install all new wiring harnesses from M&H. Wait for a YearOne 30% off sale :thumbsup:.
You're modifications are not that drastic to worry about adding to the factory system. :2cents:
Offline garity
  • 74 Challenger
« Reply #4 on: February 15, 2014 - 09:20:47 PM »
YearOne is having that sale right now.
Offline EMCD
« Reply #5 on: February 15, 2014 - 09:40:53 PM »
So, for a pro, how many hours would you say it would take to install a full wiring harness?
Offline anlauto
« Reply #6 on: February 15, 2014 - 09:43:04 PM »
If the car is complelty assembled....It will be around an hour to do all the harnesses EXCEPT the dash harness....The dash is more involved....easier to remove the whole dash....
« Reply #7 on: February 15, 2014 - 10:01:28 PM »
M&H harnesses are plug & play , they simply replace the existing harness , Painless not so much you have to terminate every single wire nothing is prefitted
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #8 on: February 16, 2014 - 01:42:12 AM »
The Painless Mopar setup will take you hours.  It is a universal one, so you need to modify it to work for your application.  Also you will need to transfer all the ends over.
With so few modifications I would get a new one from M&H and work from there.  Also I would do the Amp Meter bypass and a few other notable changes to make the system work better.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #9 on: February 16, 2014 - 02:14:23 AM »
I have the painless set up in my challenger it took a couple of weeks to figure out the front turn signals were the hardest and there tech support kinda sucks I had issues with there pure wired electric fan set up in the harness it's smoked two switches so I just hard wired it it's more painfull than painless to be honest.
Cuda james
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
« Reply #10 on: February 16, 2014 - 06:58:27 AM »
The ammeter bypass is as simple as just connecting both wires to 1 terminal on the rear of the gauge
Offline 123rmp
« Reply #11 on: February 16, 2014 - 10:32:14 AM »
First, the Year One harness was plug and play for me.  I did everything but the dash harness, which is the biggest part I know but everywhere else it was dead on right and easy.
And, Second I recommend everyone should DO the ammeter bypass.
See this article/instruction, it WORKS I did it:
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
In Mopars of this era all of the car's ammeter charging to the battery goes thru one wire thru the bulkhead connector, to the ammeter and back to the battery.  If you get corrosion on the contact surface of the engine wire harness connector or at the firewall bulkhead connector you can burn your car up.  What happens is the car pulls the amperage thru the dirty connector even though it is now a point f higher point of resistance due to corrosion.  That resistance heats up the connector (very hot) and it will melt the connector and eventually catch fire and you are in world of crap then.
If you keep the connectors like new and apply dielectric grease that is ok and how the factory intended it to work, but our cars are old indeed and you have a lot of energy going thru that ammeter which bothers me anyway.  My brand new year one harness almost went up.  I caught it when it was just really hot and starting to melt.  I decided right then to bypass the ammeter and the bulkhead entirely.  I run a big fused wire directly to the battery from the alternator.  Ammeter does not work now (I have a voltmeter) but I don't risk my car burning down by the side of the road or worse in the garage and taking it with the car or having the harness melt before I can top it (assuming I have a battery cutoff etc). I would like in the future to put a modified voltmeter in the rally dash ammeter spot, but that's another day's project.
In college in the 80s I watched a 72 or 73 Cuda burn up in a parking lot as my buddies and I could not get inside the car fast enough.  In the beginning we were afraid to hurt the hood by prying it open or to bust out the door glass to pop the hood and try to put out the fire (none of us had an extinguisher anyway)...and by the time it was clear that breaking in was the only way to save the car, it was too out of control to matter.  We did bust out the glass and try to pop the hood but by then the cable was melted thru.  Not sure what caused that fire, might have been electrical but it was frustrating.  We did not even wait to see the owner return as the cops and FD showed up.
On another note I have seen several classic cars on fire by the road.  Saw one of those expensive Cadillac Eldorado Berlitz convertibles, like a 57 or 58 go up.  I mean it burned to just a rust colored skeleton/frame sitting on rims.  I think they said a rear brake locked up and caught the wheel/tire on fire.
CARRY AN EXTINGUISHER gents.
