Author Topic: Removing Distributor Shaft Snap Ring  (Read 753 times)
Offline FCC
  • 1973 Dodge Challenger 340
« on: February 15, 2014 - 07:57:27 PM »
How the heck do I remove the snap ring from the top of the distributor shaft?  Thanks.
Offline hemiken
Re: Removing Distributor Shaft Snap Ring
« Reply #1 on: February 15, 2014 - 08:14:59 PM »
You will just have to pry it off, those things are just a C clip and not that easy to grab on to like a circlip :2thumbs:
Offline FCC
« Reply #2 on: February 15, 2014 - 09:25:13 PM »
Thanks for the information. Is it correct to assume putting it on is going to be difficult?  Thanks.
Offline Jamiez
  • Retro
« Reply #3 on: February 15, 2014 - 09:32:03 PM »
I actually found putting it back on was easier.  It was a beast to remove.  I ended up using a jeweler's screwdriver and a pair of tweezers to get it apart.
« Reply #4 on: February 15, 2014 - 11:03:11 PM »
to remove the top shaft there is a circlip in there , I assume this is the one you are trying to remove , I usually just grab one side with needle nose pliers & pull , you can rebend the clip & slide it back on
Offline hemiken
« Reply #5 on: February 16, 2014 - 08:20:17 AM »
 :iagree: Instalation is the easy part of the reassembly :2thumbs:
