Author Topic: What holds dash light panel to dash pad ?  (Read 584 times)
Offline Racer57
« on: February 16, 2014 - 10:08:14 AM »
Is there metal inside of the dash pad where the dash light panel screws go into it ? My dash light panel hangs down about 1/8-3/16" and the pad has no holes in it. Whats used to tighten the light panel to the dash pad ?
Offline JayBee
Re: What holds dash light panel to dash pad ?
« Reply #1 on: February 16, 2014 - 10:32:01 AM »
If you'rentalking about the the light bar there should be 3 holes with those metal screw clips along the top. This pic shows a couple of them.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline anlauto
« Reply #2 on: February 16, 2014 - 12:30:48 PM »
Yep...6 screws total. What pad do you have ? If it's a UR pad, there's a really good chance the holes are covered. Once you dug them out you might find the clip nuts are missing too... :2cents:
Offline Racer57
« Reply #3 on: February 16, 2014 - 01:15:09 PM »
I'm not sure what I have or even if its the original for a Cuda or not.  Hate to admit it, but I've found that I bought the car from a "flipper" and not a "restorer".  :(
Are you calling "clip nuts" the stamped steel temp nuts  ?  Where the panel goes too, the indent is in the padding but I can't find any indication of where there should be any holes. That area is just black vinyl and what appears to be Styrofoam behind it. Are you saying that if I were to place the panel in place and use a small needle probe I should be able to find the holes for screws ?
Offline blown motor
« Reply #4 on: February 16, 2014 - 01:37:43 PM »
That's exactly how you do it.
