Author Topic: Brake pushrod  (Read 1261 times)
Offline erat340
Brake pushrod
« on: February 17, 2014 - 09:38:40 PM »
Hi everyone! I got a 73 Challey, 340, factory 4 spd, pwr brakes. Ive seen a ton of adjustable brake push rods for manual. Does anyone make one for power brake? It has the bellcrank.
Offline anlauto
Re: Brake pushrod
« Reply #1 on: February 17, 2014 - 10:03:02 PM »
Every power brake system I've seen has an adjustable push rod coming out of the power brake booster. You have to remove the master cylinder to adjust it. :2cents:
Offline erat340
Re: Brake pushrod
« Reply #2 on: February 17, 2014 - 11:26:14 PM »
No not that one, thats to close the gap at the MC valve, the one comes off the pedal to the booster bellcrank.
Offline anlauto
Re: Brake pushrod
« Reply #3 on: February 18, 2014 - 06:35:07 AM »
Wouldn't they both have the same affect ? :dunno:
Offline wally426ci
    • maryland mopars
Re: Brake pushrod
« Reply #4 on: February 18, 2014 - 10:37:18 AM »
Not necessarily. You can adjust the master 1 a little for response but the pedal could need a larger adjustment. You can't really adjust the master side past contact or it engages the master system.....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline anlauto
Re: Brake pushrod
« Reply #5 on: February 18, 2014 - 11:15:53 AM »
I understand that, but how much more pedal adjustment would you need other the stock location?  :clueless:
Unless the original poster wants to get away from the stock pedal location, then of course he would be looking at modifying a piece for his individual needs :2cents:
Offline erat340
Re: Brake pushrod
« Reply #6 on: February 18, 2014 - 02:14:52 PM »
Right, just installed a 4 spd conversion, brake pedal is a scoech lower than the go. I only need it up a leeetle bit for good power brk op. Yes, the shoes are adjusted barely dragging.
Offline erat340
Re: Brake pushrod
« Reply #7 on: February 18, 2014 - 10:59:07 PM »
Answer me this if you will, Why are there several options for manual adjustable rods but not one for power?
Offline anlauto
Re: Brake pushrod
« Reply #8 on: February 19, 2014 - 06:44:11 AM »
There are none available for a factory application, there're only for people adding aftermarket master cylinders I believe. :dunno:
