Author Topic: Heater hose nipple into manifold question  (Read 3560 times)
Offline blown motor
« on: February 19, 2014 - 07:34:09 PM »
As I understand it the pre-70 manifolds were tapped for a 5/8" thread and 5/8" nipple. After that it was 1/2" thread and 1/2" nipple. My nipple is in bad shape so I ordered a nipple kit which came with a heater hose nipple and a bypass nipple. The heater nipple is 1/2" for a 73 340 engine. It doesn't match the old one which is 5/8 thread and 1/2 nipple. The manifold was cast in 72.
I hope this isn't too confusing. I know I did a poor job of explaining it. Has anyone heard of a 72 manifold tapped for a 5/8 fitting? Where can I get a fitting with 5/8 thread and 1/2 nipple? I may look for a helicoil the make the new fitting work.
Offline 72cudamaan
Re: Heater hose nipple into manifold question
« Reply #1 on: February 19, 2014 - 07:48:06 PM »
Never heard of a 5/8 thread on a car. Those pipe nipples have a pipe thread which should be 1/2". The
next larger size should be 3/4". Be careful, you can't measure a pipe thread like a normal pitch thread. Pipe threads
are quite a bit larger due to the depth requirements of the thread.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline ToxicWolf
« Reply #2 on: February 19, 2014 - 07:53:54 PM »
There are a lot of 1/2 npt to 5/8 hose. Maybe you have it backwards. Try talking to the people at Summit. They carry a lot of different size fittings like this.
Offline jhaag
« Reply #3 on: February 19, 2014 - 07:59:27 PM »
drive down to your local NAPA and ask to look through their HVAC picture catalog. They will have pictures & part number of exactly what you need and more than likely have it in stock.
love 70 Challengers
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: February 19, 2014 - 08:03:00 PM »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #5 on: February 19, 2014 - 08:21:18 PM »
I ran into the same problem. The hose nipple kit I bought came with a 1/2" nipple for the intake. The intake has a 5/8" hole in it. The correct fitting has 5/8" threads and necks down to 1/2". I found the correct one at Mega Parts but didn't want to pay the shipping for one small part. I found a fitting at Advance Auto that will work. I think I saved the box if you want the part number.
« Reply #6 on: February 19, 2014 - 08:36:14 PM »
The nipple on the far right is what comes in the kit.  The nipple in the middle is the factory piece.  It's 5/8" at the intake and necks down to 1/2" at the heater hose.  The one on the left is a nipple I found in the HELP section at the parts store.  It did NOT work.
Here is the one I bought. Four Seasons part#84712
http://board.moparts.org/ubbthreads/upload2/7201495-DSC01569.JPG
« Last Edit: February 19, 2014 - 08:40:19 PM by burdar »
Offline anlauto
« Reply #7 on: February 19, 2014 - 08:38:11 PM »
WoW...that center one would certainly be a problem solver...I run into this a lot with big blocks :2thumbs:
« Reply #8 on: February 19, 2014 - 08:42:44 PM »
I edited my above post with the Part# for the nipple I bought.  Like I said, Mega Parts sells the correct one but I couldn't justify the cost.  I think the one from the parts store was $5.  The correct one was $10 or $12 plus shipping.
Offline anlauto
« Reply #9 on: February 19, 2014 - 09:00:24 PM »
Picture saved....I didn't even know that puppy existed :2thumbs:
Offline blown motor
« Reply #10 on: February 19, 2014 - 09:24:11 PM »
Darren, the one in the middle is the one I have only yours looks a lot better than mine. The one on the right is what I got in the kit. I don't think we have Advance Auto here in Ontario and shipping across the border would be a lot more than $12. Hmmmm  :clueless:
« Reply #11 on: February 19, 2014 - 10:04:43 PM »
Look in the link I posted. That brand should be sold in other parts stores I think.
Offline blown motor
« Reply #12 on: February 19, 2014 - 10:37:55 PM »
I googled Four Seasons part # 84712. It's available from lots of places. Of note was Amazon.com (US) for 6.29 and Amazon.ca (CDN) for an amazing 21.96 :22yikes: Unbelievable.
Thanks Darren. I'm sure I'll get one, just need to figure out where.
Offline 72cudamaan
« Reply #13 on: February 20, 2014 - 09:06:33 AM »
Actually the one in the middle is 1/2" pipe thread and the one on the right is 3/8" pipe thread. The one on the left looks to be a straight thread so it definitely won't work. A pipe thread is tapered so you will get a different measurement depending on where you measure it. Again, there is no such thing as a 5/8" pipe thread.
« Last Edit: February 20, 2014 - 09:08:45 AM by 72cudamaan »
« Reply #14 on: February 20, 2014 - 10:10:06 AM »
The one on the left screwed into the manifold just fine.  It's the heater hose that wouldn't stretch over the end.  That's what happens when you don't have the old part in hand when you're at the parts store.  I'm pretty sure the hole in the intake was 5/8" in diameter.  That must translate to 1/2" pipe thread?
Summit lists one as well...
http://www.summitracing.com/parts/fss-84712
« Last Edit: February 20, 2014 - 10:19:09 AM by burdar »
