Author Topic: Upper Steering Wheel Bearing?  (Read 790 times)
Offline Prime72
« on: February 21, 2014 - 08:15:55 PM »
So, I was replacing my ignition switch today, tearing down the steering column, and accidentally broke the small ball bearing peice that goes around the shaft and inside of the 2nd metal casing (the one that holds the turn signal/hazard). This is right before you get to the lock plate. There was also a rubber ring around it. Hope that is clear. Any idea where to get a replacement or what its called? Thank you very much
Offline Moparparts
Re: Upper Steering Wheel Bearing?
« Reply #1 on: February 21, 2014 - 08:27:21 PM »
I have a good used original one PM or e-mail if interested
Offline Prime72
« Reply #2 on: February 21, 2014 - 09:21:18 PM »
Thank you, PM sent
Sent from my SGH-M919 using Tapatalk
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #3 on: February 21, 2014 - 11:36:35 PM »
You can also buy them new at any Dodge dealer.  Sometimes they are in stock even.  They were used on steering columns for something like 20 years.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline 74challenger03
« Reply #4 on: March 04, 2014 - 07:43:38 PM »
did you get one prime72?
« Reply #5 on: March 04, 2014 - 11:03:48 PM »
That's where i got mine a couple years ago. Not cheap for such a small bearing though. I think I paid something like $44.
Offline Prime72
« Reply #6 on: March 08, 2014 - 11:51:16 PM »
Thanks for the interest, I did not get the bearing yet. Focusing on getting the car to run. Got er cranking so I know I'm close... will probably hit the junkyard to hopefully find that bearing for cheap
