Author Topic: Testing Dash  (Read 2645 times)
Offline 72cudamaan
Testing Dash
« on: February 22, 2014 - 10:17:23 AM »
So I'm thinking of hooking up a battery charger to my dash while it's on a stand. Maybe hook up the steering column
at the same time. Anyone think of a good reason why this might be a bad idea? I am just hoping to make sure everything
works properly before putting it in the car. Thanks for any input.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline usraptr
Re: Testing Dash
« Reply #1 on: February 22, 2014 - 10:26:23 AM »
 :popcorn:
(Edited 8-1-17)
Re: Testing Dash
« Reply #2 on: February 22, 2014 - 02:42:08 PM »
Andy,
 I'm not sure what you can accomplish here, other than not seeing smoke. The gauges won't respond until they get input from their sending units. If you have Rally gauges, the clock would work.
Offline 4Cruizn
  • HEMI FISH
Re: Testing Dash
« Reply #3 on: February 22, 2014 - 02:44:47 PM »
I remember when Redline did that with his dash for the challenger . . . Didn't have any issues that I remember.
Offline Jamiez
  • Retro
Re: Testing Dash
« Reply #4 on: February 22, 2014 - 03:17:12 PM »
You can build a gauge tester using a few cheap parts and a 5v source (you can usually find a phone charger or similar that is 5v).  You can find some details here:
http://www.dodgecharger.com/forum/index.php/topic,37999.0.html
Towards the end of the first page he goes over the testing
Offline 72cudamaan
Re: Testing Dash
« Reply #5 on: February 22, 2014 - 05:49:47 PM »
I was figuring on testing the turn signals,dash lights,plug in the headlight harness and test for power at headlights, dome light
In general, just checking for power at all of the connectors.
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Testing Dash
« Reply #6 on: February 22, 2014 - 08:44:29 PM »
Offline edl94
  • She Cuda
Re: Testing Dash
« Reply #7 on: February 22, 2014 - 10:04:20 PM »
Whatever you decide to do don't use a battery charger by itself. Without a battery the charger will have no reference for its output and could pump out unsafe voltage and amperage levels.
Offline 72cudamaan
Re: Testing Dash
« Reply #8 on: February 22, 2014 - 10:58:20 PM »
Hadn't thought of that. Just assumed the charger would put out 12 volts. Thanks for the heads up.  :2thumbs:
Offline 72cudamaan
Re: Testing Dash
« Reply #9 on: February 22, 2014 - 10:58:56 PM »
Offline publicbottle
Re: Testing Dash
« Reply #10 on: February 23, 2014 - 03:14:14 AM »
sometimes i use my drill battery (14.4V) as a power source for testing random things on old automotive systems. seems to work fine with a couple jumpers and alligator clips :2cents:
Offline usraptr
Re: Testing Dash
« Reply #11 on: February 24, 2014 - 01:58:49 PM »
My son, the mechanic, came over this morning and we tested my Rallye gauge cluster.  Fortunately all the gauges, clock and speedo works.  However, we couldn't figure out how to test the tach.  Is there any way to bench test the tach or do you have to have it hooked up to a running motor? :feedback:
(Edited 8-1-17)
Re: Testing Dash
« Reply #12 on: February 24, 2014 - 03:47:27 PM »
There is a way to bench test a tach, but I don't know it for sure.   :banghead:
I have a feeling it involves a signal generator being connected to the signal wire of the tach.  You vary the frequency of the signal generated, your tach should respond accordingly.  Now, just what frequency is = to 1000 RPM's, I don't know. I'm in over my head here.    :bricks1:
« Last Edit: February 24, 2014 - 03:55:28 PM by MEK-Dangerfield »
Offline usraptr
Re: Testing Dash
« Reply #13 on: February 24, 2014 - 09:11:46 PM »
Thanks MEK-Dangerfield.   :2thumbs:  That's what I thought.
(Edited 8-1-17)
Offline 73EStroker
Re: Testing Dash
« Reply #14 on: February 24, 2014 - 10:46:31 PM »
Andy, did you upgrade the tach and clock? If so RTE has a tach exerciser that swings the tach from zero to full scale continuously. It also calibrates the tach at 1000/4000 rpm. I have an exerciser that does this but live in Western Canada. Also you can hook 12 v to your gauges but make sure you are on the correct terminal. Then you can ground out the oil, gas and temp gauges, on the sensor connection terminals, to watch them go to full scale.
Barry (Salmon Arm)
