Author Topic: Powering amp question  (Read 1836 times)
Offline Fern
« on: February 22, 2014 - 04:26:20 PM »
I have already run 2 power cables from battery to trunk. one was going to be for amp and the other for a powered sub. Well the wires are 8 gauge, with 60amp fuse, which was fine when run last year. A friend of mine gave me a alpine pdx-5 amp, which requires a 4 gauge wire with 60 amp fuse.
my question is can I still run the 8 ga wire (since they are both 60 amp fuses), or if not can I use both wires and tie the ends together even though they are seperate wires?
Thanks
Re: Powering amp question
« Reply #1 on: February 22, 2014 - 05:15:42 PM »
Offline Fern
« Reply #2 on: February 23, 2014 - 10:35:21 AM »
Ok, from the chart provided I need a 4ga wire.
Can I use the 2 seperate 8ga wires I have already run and tie them together at each end and work?
Trying not to have to pull the carpet and seats out to run a new wire.
Thanks
« Reply #3 on: February 23, 2014 - 02:08:46 PM »
I wouldn't fret too much with this. If you want to use two 8ga wires, that will be fine.
I don't recall the size of wire I have running to my trunk for an aftermarket amp, but it came with a 30 amp fuse that was toast from the factory (How does that happen?). So I installed a 15 amp fuse in it's place, since that was the only fuse I had that would fit. The 15 amp fuse has never blown.  I have since bought 30 amp fuses, but haven't had a need to use them yet.
So my point is, I think they lean on the side of caution with the wiring and fuse size. This is my opinion of course.    :2cents:
« Reply #4 on: February 27, 2014 - 08:21:26 PM »
2 8 ga wires should handle the load easily but it may not be protected properly using 2 60 amp fuses as it would take 60 amps down each wire to cause the fuse to blow so you would want to tie both wires to a single fuse
Offline GreenFishie
« Reply #5 on: March 07, 2014 - 02:39:45 PM »
A little late but .... you should be fine so long as you're not taxing your amp and pushing something like 100 RMS constantly. Seriously ... you'll go deaf.
It's a nice amp and I don't know too many people that would hand over a 700 dollar piece of automotive sound equipment. That's a serious amp, and a class D to boot. You need to protect it.
Get a 4 gauge fused distribution block, take both of your 8 gauge wires and clean them up. Cut the exposed ends off and re- strip them and then couple them with solder. Do not twist them together. Connect that to the block and then run a short stretch of 4 gauge to the amp.
This way if there's a load issue it will happen at the block and not at your amp.
Class D amps can be fickle and are a bit more delicate than older mosfets.
Offline Fern
« Reply #6 on: March 07, 2014 - 05:51:10 PM »
Thanks, great advice   :2thumbs: :2thumbs:
« Last Edit: March 07, 2014 - 05:53:02 PM by fern »
