Author Topic: A-Body 8.75 rear axel  (Read 1540 times)
Offline RAD1229
  • 72 Challenger
« on: April 12, 2005 - 06:08:17 PM »
  What is the diffence between the A body 8.75 and the e-body 8.75??
1972 Challenger
Offline 4Cruizn
  • HEMI FISH
Re: A-Body 8.75 rear axel
« Reply #1 on: April 12, 2005 - 06:13:55 PM »
One is wider than the other.   :thumbs:
Offline RAD1229
  • 72 Challenger
« Reply #2 on: April 12, 2005 - 06:50:10 PM »
is the e-body wider? or the A-body?
1972 Challenger
« Reply #3 on: April 12, 2005 - 11:01:48 PM »
the A body is much naroower & harder to find too
http://www.mymopar.com/axledims.htm
Offline RAD1229
  • 72 Challenger
« Reply #4 on: April 13, 2005 - 07:48:07 AM »
 :thumbs: Thanks Chryco,
  What kind of Problems would i run into If I attempt to swap from my stock rear axel to the A- body axel?   Or can this swap be performed?
1972 Challenger
Offline 360 'CUDA
« Reply #5 on: April 13, 2005 - 01:08:59 PM »
The B-body 8 3/4 rear is the way to go on this swap  (1963 to 1970 B-body)
The A-body 8 3/4 has too many issues not the least of is the smaller bolt pattern and the limited availibility
The B-body rear is the right size to use the spring relo kit and will most likely have the bigger brakes and
upgraded third member.  (A-body rears most often have the 741 case instead of the 742 or 489 which are
stronger)
Offline RAD1229
  • 72 Challenger
« Reply #6 on: April 14, 2005 - 08:06:48 AM »
 :iagree:  I did some reading as well as viewed a few earlier posts here on C-C.C  I had had meade the same deduction.  Thanks for the heads up though.   Thats what I like about this site everyone's always watching your back!! :thumbs:
1972 Challenger
